'03 CTS won't start, crank, or turn over -- CPS or starter?
Results 1 to 4 of 4
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, '03 CTS won't start, crank, or turn over -- CPS or starter? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I have an '03 CTS with 119k miles on it. Suddenly today it won't start. I turn the key, I ...
    jimsimm1 is offline Cadillac Owners Member
    Jun 2012
    21
    I have an '03 CTS with 119k miles on it. Suddenly today it won't start. I turn the key, I can hear a relay or two clicking, some whirling and buzzing sound in the engine but nothing else. Battery shows 12.4 volts, lights etc are working. I do have two codes that are related to the crankshaft position sensor: P0335 and P0341 but I have gotten these intermittently for the past year. And I've read here that if it doesn't even crank, it's not the CPS. Makes sense to me. But since that starter really doesn't look too fun to get at to replace, I want to eliminate other possibilities first.
    By the way, it looks like I have to remove the Cat to get to the starter -- are those bolts very difficult to get at and get off? I imagine they can be seized up pretty good with all the heat.
    thanks!
    cabletech is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS 3.2L M35 LtPt
    May 2010
    223
    Re: '03 CTS won't start, crank, or turn over -- CPS or starter?
    When my CPS failed, it would crank (starter would turn the engine over) but would not start. I did have a couple of instances where the car did nothing (during the time the CPS was failing, before I changed it), but 95%+ of the time, it would simply crank and not start.
    I also ended up changing the cam position sensor. I had recurring CPS codes (even with a new CPS) until I changed the timing belt and cam sensor. Since then, no codes (for that, anyway). If you're hearing a click-whirr, it very well may be the starter. Spray Liquid Wrench on the exhaust manifold bolts on Friday night, take it apart Saturday morning. Should come apart just fine.
    tonysilva530 is offline Cadillac Owners Member
    Automobile(s): NONE
    Nov 2013
    California, USA
    44
    27
    Did you fail to mention the size engine in your CTS?
    I recently replaced the starter on a v6 CTS. These are the tools I used:
    13mm wrench
    15mm socket with short extension on a ratchet.
    For the CTS V6 that I was working on needed the starter replaced. There were 2 possible types of starters that could've fit this particular car. One of them is called "anti-rotation" ....whatever that means. But it costs about $100 MORE than the other one.I thought I was going to have to remove the cat converter or a motor mount, but I didn't. If you unclip and move the stiff wire hrness to near the side of the starter, it will come right out. Super easy.
    Ikera's Avatar
    Ikera is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac CTS 3.2, 1990 Nissan 240sx Turbocharged
    Apr 2013
    Vancouver, BC
    30
    383
    Quote Originally Posted by tonysilva530 View Post
    13mm wrench
    2003 CTS only came with 3.2L not the same as the rest of V6s
  7. Remove Advertisements
