Whirring Sound Front Left????
Results 1 to 9 of 9
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Whirring Sound Front Left???? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; When I'm going over 40 and make a slight turn to the left(lane change) I here a whirring/rubbing sound coming ...
    simkofab is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2006
    Northwest Indiana
    50
    When I'm going over 40 and make a slight turn to the left(lane change) I here a whirring/rubbing sound coming from
    the left front wheel. The car runs fine still. Also this morning after starting it was whining. 45 degrees outside. Both the engine and steering.The sounds went away after warming up. I don't recall this before until it was much colder. Should I be concerned?
    DopeEffect's Avatar
    DopeEffect is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 3.6L CTS, Hotchkis Sway Bars, FE2
    Jul 2012
    Dallas, TX
    27
    524
    Re: Whirring Sound Front Left????
    As far as the rubbing/whirring sound idk but the whining noise could possibly be your power steering pump pulley. I had this issue for a long time in the cold months. Sprayed some wd-40 on the back of all the pulleys when I replaced both belts. Issue wen't away.
    arw1510 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS 3.6, 2004 SRX 4.6 AWD, 2012 CTS 3.6 DI AWD
    Oct 2008
    1,229
    Hub bearing? But usually if you turn left and it makes a noise, then it's the right hub bearing, and turn right it's the left front one.
    Jack the car up, and spin the front wheels by hand. If there is a problem then you should be able to feel the difference.
    Usually like 150 in parts and 1.5 hrs labor
    MrCatch is offline Cadillac Owners Member
    Oct 2013
    6
    Mine makes a slight rubbing sound when turning slight right and it feels like it's coming from front driver side. I'll be looking into this hub bearing. Glad I stumbled upon this.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Quote Originally Posted by simkofab View Post
    Hello simkofab,
    I am sorry to hear that you are experiencing this concern with your CTS making a whirring or rubbing sound. I see that you have gotten some great advice from the community members here, but if you are concerned and are thinking about taking your vehicle to the dealership, I would be more than happy to assist you in working with them to look into this concern. Please private message me if you would like to further discuss your concern. Thank you very much for your time.
    Gregory W.
    Cadillac Customer Care
    Quote Originally Posted by MrCatch View Post
    Hello MrCatch,
    I am sorry to hear that you are experiencing a slight rubbing sound when you are turning right. Please feel free to private message me or send me an email to socialmedia@gm.com if you will be taking your vehicle to a dealership and would like any assistance working with them to look into this concern. If you send an email, please be sure to include “ATTN GREG” in the subject line so that it gets delivered straight to me. Thank you very much for your time.
    Gregory W.
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,217
    A bad wheel bearing will typically make a rhythmic wah-wah-wah-wah-wah noise that gets faster (and possibly louder) as the car speeds up. You may not hear it at lower speeds. If you're on an open stretch of road, and going fast enough that you can hear the noise, try smoothly weaving back and forth - you'll hear the noise change as you change the load on the bearing from one direction to the other. You can see that a bit in this video (and I'm sure there are others on youtube, I just looked for a short one.)
    Unless the wheel bearing is really, really bad, jacking each corner up and spinning the wheel generally won't tell you anything. However, if you jack each corner up, then grab the tire at 12 o'clock and 6 o'clock and try to rock it. If it moves at all, that's bad. Here's an example video of a bad bearing.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    Jim's 06 is offline Cadillac Owners Fanatic
    Nov 2006
    191
    I vote for wheel bearing. They can make just about any sound (or none at all) when they go bad. My daughter's Saturn made a noise like the old playing-card-in-the-spokes noise seemingly from the front of the car, and it turned out to be a rear wheel bearing
    Regalgs98s is offline Cadillac Owners Member
    Aug 2008
    4
    +1 on the wheel bearing. I thought that just from the title and pretty sure from reading through. As it was said, I'd check to see if the pitch changes at higher speeds also.
    Jaxle67's Avatar
    Jaxle67 is offline Cadillac Owners Member
    Automobile(s): 2004 cts
    Nov 2012
    savannah ga
    95
    I replaced my driverside front wheellbeairng assembly on my 04. it never did make any kind of nose that i could hear. It did however had a rumbling feeling that you could feel thru the steering wheel. I jacked up the wheel and grabbed the tire at 6 and 12 position and wiggled. I had atleast an inch of movement so i immediately put a new hub assembly on that side and a couple weeks after replaced the passenger aside as well. I agree most of the time you will hear a roaring noise but not always. Its easy enough just to jack it up to check out ever so often even if there are no clues that a bearing maybe on the way out. Jesse
  12. Remove Advertisements
