2007 3.6 Engine Noise and Code P0024
Results 1 to 4 of 4
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 2007 3.6 Engine Noise and Code P0024 in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Engine was seized due to low oil. Got it loose and running with a knocking noise (piston slap?) and code ...
    rmarc7828 is offline Cadillac Owners Member
    Automobile(s): 2007 CTS
    Sep 2013
    66
    Engine was seized due to low oil. Got it loose and running with a knocking noise (piston slap?) and code P0024 set (Exhaust timing bank 1 24%).
    Pulled front cover to check timing chains. Nothing amiss (was changed at 10k miles now has 40k) with chains and sprockets. Found aluminum flakes in each of the VVT solenoid valve screens more on right side.
    Pulled and disassembled oil pump. OP is perfect and contained no debris. Front cover has no damage. Where is the aluminum coming from?
    Calgary03's Avatar
    Calgary03 is offline Cadillac Owners Fanatic
    Automobile(s): 03 Cts Sport Luxury
    Feb 2013
    Calgary Canada
    29
    117
    Probably the connecting rod bearings. They got worn down due to heat and lack of lubrication. The noise you hear is the rod banging against the bearing/crankshaft as there is too much clearance. Only fix is complete rebuild, replacement engine or new car
    Sep 2013
    66
    Re: 2007 3.6 Engine Noise and Code P0024
    Are the rod bearings aluminum? I found aluminum particles in the VVT solenoid valve screens.
  5. #4
    Calgary03's Avatar
    Feb 2013
    Calgary Canada
    29
    117
    If you're sure it's aluminum, then my guess would be the block
  6. Remove Advertisements
