Hard shift out of park in gear, and strongly felt downshifts
Results 1 to 13 of 13
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Hard shift out of park in gear, and strongly felt downshifts in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; okay, so ive searched a bit, and the answers i found in those threads were motor and trans mounts. both ...
    arw1510 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS 3.6, 2004 SRX 4.6 AWD, 2012 CTS 3.6 DI AWD
    Oct 2008
    1,229
    okay, so ive searched a bit, and the answers i found in those threads were motor and trans mounts. both of which ive replaced.
    When i shift into drive or reverse, whether from park or neutral, it is an extremely firm shift, and the car physically moves. I also think the downshifts when coming to a stop are strong also.
    2004 CTS 3.6 155k miles. new motor mounts and trans mount.
    Any other ideas?
    CTS-QC is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS 3.6L V6 RWD Performance
    Dec 2012
    Montreal
    136
    Re: Hard shift out of park in gear, and strongly felt downshifts
    How many rpms does it idle at? Just asking because you didn't mention that. Is it idling too fast?
    Oct 2008
    1,229
    Quote Originally Posted by CTS-QC View Post
    I didn't notice a difference there so im assuming its normal. I'll get you a # tomorrow
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,391
    When was the last time the fluid was changed? I'm not an auto tranny guy, but from what I've gathered over the years, lots of auto trans issues are resolved by a fluid change.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    Oct 2008
    1,229
    Quote Originally Posted by AAIIIC View Post
    Never. The dealer actually told us that by doing so we would end up creating more problems than solutions and that we wouldn't like how it felt afterwards. The guy at AAMCO said the same thing, that its not worth just doing fluid on that trans
    krusty_tc is offline Cadillac Owners Member
    Automobile(s): 2003 CTS Luxury Sport
    Apr 2013
    52
    51
    Mine did the hard shifting after a difficult time starting the engine. Happened to me twice. I disconnected the battery for approximately 2 hours before reconnecting it. And make sure you do the gas pedal relearn before starting the engine. This worked for me both times. Doesn't hurt to try.
    praprestoabi's Avatar
    praprestoabi is offline Cadillac Owners Fanatic
    Automobile(s): 04 CTS, on my 2nd 2010 CTS wagon
    Sep 2012
    Charlotte, NC
    191
    Quote Originally Posted by krusty_tc View Post
    Gas pedal Re-Learn?
    Apr 2013
    52
    51
    Throttle re learn process.
    AAIIIC's Avatar
    Aug 2007
    6,391
    Quote Originally Posted by arw1510 View Post
    So what's their suggestion? Live with it until the transmission dies? Have they done any diagnostics on it? Hard shifts can be caused by all sorts of things, and the FSM specifies a diagnostic procedure the dealer can go through with the Tech2 and test the various solenoids and communication paths.
    There's a fluid and filter change procedure in the FSM for a reason. There's a 50,000mi service interval for it in the Owner's Manual. There are plenty of people on this forum who have changed their fluid. I don't understand why you would be advised that changing the fluid would make things worse.
    DopeEffect's Avatar
    DopeEffect is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 3.6L CTS, Hotchkis Sway Bars, FE2
    Jul 2012
    Dallas, TX
    27
    524
    Only time I've ever heard anything close to that is when a transmission has gone so long without a fluid change that flushing it will destroy the trans. This happened to my 4L60E. Flushed it, a few days later tranny was dead. A simple drain and refill probably would of kept it alive. But yea that was only for flushing a trans, not changing the fluid. Changing the fluid should do no damage to your trans unless something else is wrong with it.
    ztollon's Avatar
    ztollon is offline Cadillac Owners Enthusiast
    Aug 2012
    629
    The trans itself wont die. Fluid that has been neglected can carry clutch particles which act like a friction modifier. This fluid is removed w a flush. Now how long you have before your trans goes out is hard to say. It could happen as your leaving the shop that you had the work done at, or a month later.
    Rule of thumb at my shop. If its over 125k w/o ever having a trans flush then we wont touch it.
    Oct 2008
    1,229
    I'm not so sure its trans though. The downshifts maybe. But with the shift to park and reverse, the trans engages and then the whole car tries to move. All up shifts care smooth. Idle is fine. Idk. Next amex cycle I suppose I'm stuck bringing it into the dealer
    Leects07's Avatar
    Leects07 is offline Cadillac Owners Member
    Automobile(s): 07 cts sport/luxury pkg
    Jun 2013
    Memphis
    34
    59
    My car started doing this last night 37k miles hard down shifts not so much when moving from park but the up shifts are firm and the down shifts are real strong ....also before all this started I jumped into my car and tried to crank it first to try's nothing then it cranked Got home disconnected battery overnight ..gonna re connect here in a sec and see what happens
    Edit from my last post ..reconnected the battery turned key to on position could here the throttle motor flapping and I guess learning its parameters .. Let it sit for about two minutes took it for a drive and it's down shifting smoothly again and acting normal ...
  16. Remove Advertisements
