Wiper washer motor
Results 1 to 13 of 13
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Wiper washer motor in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hello forums I just joined I am having a problem with the washer motor That stays on no matter what ...
    big lou is offline Cadillac Owners Member
    Sep 2013
    6
    Wiper washer motor
    That stays on no matter what speed the wipers
    Are at has anyone else had this problem
    What was the cure sorry 06 cad cts
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    Re: Wiper washer motor
    Welcome to the forums
    (you're probably going to moved over to another area once the moderator picks this up)
    It's probably a bad relay or motor.
    68
    81,916
    Blayne's Avatar
    Blayne is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS sport model/package
    Sep 2012
    Sudbury, Ontario Canada
    1,058
    You need a new wiper motor cover. Not the whole motor, just the cover. The cover has a circuit board inside it that gets condensation in it and ends up doing what it's doing to you. Go to the gmonlineparts store. They are the cheapest.
    Sammy Z's Avatar
    Sammy Z is offline Cadillac Owners Connoisseur
    Automobile(s): CTS 03
    Jan 2008
    Chicago, IL
    1,765
    Yes, the circuit PCB in the cover of the motor is bad, common problem, Order the replacement cover , it's not hard to install.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Welcome big lou! As Customer Care advisors, we aren't able to help with technical or DIY questions, but if you have any questions you need answered about warranty, recall issues, or would like further support in working with a dealership, we're here.
    Sarah (Assisting Laura)
    Cadillac Customer Care
    cadillac71 is offline Cadillac Owners Member
    Automobile(s): 2004 CTS & 1998 Deville
    Jul 2013
    I'm having same issue. Where's the motor located, I'll look into it soon?
    Sep 2013
    6
    Quote Originally Posted by cadillac71
    i
    I know that the motor on the 06cts is located under the hood driver side back by the firewall
    Sep 2013
    6
    Quote Originally Posted by big lou
    i I know that the motor on the 06cts is located under the hood driver side back by the firewall
    hello did you ever get the problem figured out pls let me know what the problem was if you did thanks
    Blayne's Avatar
    Sep 2012
    1,058
    I can tell you almost 99.9% that it was the wiper motor cover. Happens all the time. You need to access the motor and replace the rear cover.
    Sep 2013
    6
    Thanks man I called the dealer today they said that part cost 225.00 and they want another 232.00 for install man are they crazy or what
    Pete(UK)'s Avatar
    Pete(UK) is offline Cadillac Owners Fanatic
    Automobile(s): CTS 2007 Sport Luxury
    Mar 2013
    London, England.
    126
    Oddly enough, here in the UK, our wipers are on the other side than yours and so too is the master cylinder.
    Our CTS's here had a recall on the master cylinder, as it was prone to getting waterlogged and go rusty, so we had a plastic one fitted.
    Looks like that particular spot is a water hazard.
    mckeeby is offline Cadillac Owners Member
    Oct 2013
    35
    1
    I recently had this same problem. I was quoted $200-$450 for the part from dealers and auto shops plus labor. Ended up purchasing just the motor from Rockauto online for about $60 and took me about 25 minutes to replace. Works like a charm and haven't had a problem since. There is a youtube video detailing the replacement process. Search for '2003 Cadillac CTS wiper motor removal'. I found it to be a very easy fix. Good luck.
  16. Remove Advertisements
