Replaced Theft Deturrent module, Car thinks it's stolen
Results 1 to 7 of 7
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Replaced Theft Deturrent module, Car thinks it's stolen in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Title says it. I know that the standard method is to take the car to a dealer, but I'm wondering ...
    propninja's Avatar
    propninja is offline Cadillac Owners Fanatic
    Automobile(s): CTS
    Jul 2005
    Los Angeles
    178
    Title says it. I know that the standard method is to take the car to a dealer, but I'm wondering if there is an independent mechanic with a Tech II scanner that cab do the work? The intent being to save some cash. Or do I have other options? I'm in the los Angeles Area, any helpfull suggestions will be greatly apreciated.
    Thanx
    Wendel
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,455
    Re: Replaced Theft Deturrent module, Car thinks it's stolen
    I'm pretty sure there is a relearn procedure you can do with just your key and key fob. I'll try to remember to look for it in the FSM after work today.
    I know there's the "30 minute relearn" that you can do if you replace the ECU/ECM - I just had to do that a couple weeks ago. But I think the TDM relearn is a different procedure.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    propninja's Avatar
    Automobile(s): CTS
    Jul 2005
    Los Angeles
    178
    Thanks.Yea, I know About the 30 min relearn procedure (there's also a 10min procedure) but according to the service manual they both require a Tech II to initiate the procedure. Of course the manual assumes you have A Tech II handy. I'm hoping for a work around and extra pairs of eyes helps.
    AAIIIC's Avatar
    Aug 2007
    6,455
    I forgot to look it up yesterday, so I don't know what the relearn process is for the TDM. I know the whole point of the 30-min relearn is that you don't have a Tech2 to use. It requires nothing other than a key that was previously programmed to the car. I've done it on 2 or 3 occasions, no Tech2, just me in my driveway or garage.
    AAIIIC's Avatar
    Aug 2007
    6,455
    So I finally remembered to look up the procedures. The 10-min relearn does require the Tech2. Both the 10-min and 30-min relearns say that if you're replacing the TDM, you have to perform the procedure to setup a new TDM (which also requires a Tech2) before doing the relearn.
    Sounds like you're screwed. Even if you find an independent mechanic with a Tech2 I'm guessing you won't save much money - it'll probably be 1hr labor either way.
    propninja's Avatar
    Automobile(s): CTS
    Jul 2005
    Los Angeles
    178
    Well six hours and $200 later, my car runs but I still have the same problem I started with. "service theft deterrent system" The only thing i know for sure is that it's not the theft deterrent system. But I have a clue. See new thread water in driver's footewell
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Mar 2010
    Detroit, USA
    12,710
    Quote Originally Posted by propninja View Post
    Hello propninja,
    I am sorry you are still experiencing issues with your service theft deterrent system module. I know you mentioned wanting to go around working with a dealer, however due to the issue still occurring, if you are willing to work with a dealer please let us know. We can be contacted via private message.
    Sincerely,
    Laura M.
    Cadillac Customer Care
  10. Remove Advertisements
