Rear wheel bearing
Results 1 to 10 of 10
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Rear wheel bearing in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; How many people have had a rear wheel bearing go bad? My car has about 110k miles. I have a ...
    maximusdecimus is offline Cadillac Owners Member
    Automobile(s): 2006 CTS 3.6L
    Apr 2011
    Atlanta, GA
    42
    12
    Rear wheel bearing
    How many people have had a rear wheel bearing go bad? My car has about 110k miles. I have a noise I think is coming from the right rear. I don't think it is the tire. Noise seems to change if I do a really hard yank on the wheel to the right (unloading the right rear tire) so I don't think the noise is coming from the rear end.
    Is the bearing hard to replace?
    Sent from AutoGuide.com App
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,063
    Re: Rear wheel bearing
    I replaced one of my rear ones on my CTS at about 80k IIRC...It's not hard, except the E-Brake mechanism can be a PITA to get back together...
    - Remove wheel
    - Remove brake caliper
    - Remove rotor
    - Remove bad wheel bearing
    - Install new wheel bearing
    - Put it all back together
    Done
    If it the noise changes when you go from side to side it is more than likely a bad bearing, if you yank to the right and it gets louder the bad bearing is on the driver side and vice versa. I suggest either going with OEM (spendier) or a Timken or SKF bearing, if you go cheap you'll be doing it again before you know it.
    CTSM is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 08' 3.6 DI Performance | 07' Lux 3.6 Volant-Borla-Vsways
    Mar 2012
    943
    I've done it before, out of error, replaced rear left hub assembly with Timken unit (best option IMHO) it really sounded like I had a bad bearing, turned out it was my rear driver side snow tire making strange noise back then, ooops oh well I keep the old hub handy just in case the rear right one goes bad I'll make use of it hehe
    CTS-QC is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS 3.6L V6 RWD Performance
    Dec 2012
    Montreal
    137
    Had it happen to mine, at around 80k miles. Thought it might have been the diff, but was the right rear wheel bearing. It sounded rather like I had an outboard boat motor in the back. The mechanic said he had a really tough time taking off the old one, so don't be surprised if it isn't an easy job.
    DopeEffect's Avatar
    DopeEffect is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 3.6L CTS, Hotchkis Sway Bars, FE2
    Jul 2012
    Dallas, TX
    27
    524
    Quote Originally Posted by curtc View Post
    - Remove wheel
    - Remove rotor
    Done
    Is the process the same for the front wheel hubs/bearing assembly?
    josney's Avatar
    josney is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS
    Dec 2006
    South Carolina
    50
    2,307
    Quote Originally Posted by DopeEffect View Post
    yep, very simple process for the fronts.
    DZarzour is offline Cadillac Owners Member
    Mar 2005
    37
    don't buy the cheap bearings I had mine replaced a year ago I bought the cheap $99 jobs from 1a auto 6 months later one of them failed replaced it now the other side has failed I'm going to bite the bullet and spend the 450 bucks on Timkens. I will say this for 1 a auto they are giving me a credit for the replacement but I will have had to pay to do the job two and a half times
    by the way can anyone tell me why the 03 to 07 rear bearings are for $455 and the 08 bearings are $266?
    Mar 2012
    943
    Quote Originally Posted by DZarzour View Post
    RockAuto.com has the Timken Rear hub for $194.79 and the Timken front hub for $132.79. That's your answer you are buying them overpriced.
    Mar 2005
    37
    450 is for a pair, so they are not too far out of line, and the fact remains no matter where i've looked 03-07 rear bearings are about twice what 08's are
    450 is for a pair, so they are not too far out of line, and the fact remains no matter where i've looked 03-07 rear bearings are about twice what parts fro the 08's are
    AmericanMuscle is offline Cadillac Owners Fanatic
    Mar 2005
    260
    Get the SKF hub assemblies instead. You can also find them on Rockauto.com. Best replacement by far.
  13. Remove Advertisements
