Tranny Fluid?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
Like Tree1Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Tranny Fluid? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Ok guys, I am usually the one that says do a search when someone asks a simple question. But, I'm ...
    Blayne's Avatar
    Blayne is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS sport model/package
    Sep 2012
    Sudbury, Ontario Canada
    1,058
    Tranny Fluid?
    Ok guys, I am usually the one that says do a search when someone asks a simple question. But, I'm knee deep in multi vehicle repairs and I have been in the garage for days.
    I need to know how much fluid our tranny (auto) takes. I blew my tranny line and I am doing the exterior cooler and need to fill it.
    Thanks to who ever replies!!!!
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,121
    Keep in mind that the external cooler is gonna hold a different volume amount as compared to the factory. I can't even begin to say which way, more or less. But I know that the factory specs for transmission fluid are in the owners manual. And I believe that it's 9.5qt. Just double check the owners manual.
    KOT
    Blayne's Avatar
    Sep 2012
    1,058
    Ok thanks KOT. I thought I remembered it being around 10 qts of Dexron 6 or something. And I was thinking the same on the amount. After I add the factory requirements, I will run it thru the gears as per the manual and I will have to add or remove as needed. I say remove but I actually mean watch it pour out of the fill hole lol.
  5. #4
    Apr 2009
    Ledyard, CT
    37
    9,121
    Quote Originally Posted by Blayne
    Ha ha
    I need to add some to mine. When my external was installed last year. None was added, so whatever was in the factory cooler never made it back. Drove around like that for over 10,000 miles. Just last month I had had a flush done. But the flushing machine only puts it what it takes out.
    However, had a kid who only done one other flush. So he was fumbling around as fluid poured out.
    So would you let me know what size the bolt/socket is for the full hole. And what did you use to make the fluid from the bottle to get into the transmission. Lol
    KOT
  6. #5
    Blayne's Avatar
    Sep 2012
    1,058
    I will be using a transfer pump. That I know for sure. But I will let you know what the size is for the fill plug!
  7. #6
    Iceman_jd's Avatar
    Iceman_jd is offline Cadillac Owners Fanatic
    Automobile(s): 2007 3.6 CTS
    Oct 2012
    Arizona
    112
    Re: Tranny Fluid?
    Quote Originally Posted by Kingoftypos View Post
    Ha ha
    KOT
    KOT it's a torx t45 and I used the cheap red universal transfer pump from Harbor freight, I think its usually on sale for around $5 bucks and works great.
  8. #7
    Blayne's Avatar
    Sep 2012
    1,058
    Yup, T-45 was the right tool. I drained the oil that was left in the tranny. Tranny refill with external coolers was 8 liters. 8.5 US qts. I am sure there was probably a bit of oil left in the torque converter and whatnot so that's why it only took 8 liters. External cooler took about 30 minutes to install and was a breeze.
  9. #8
    Apr 2009
    Ledyard, CT
    37
    9,121
    I've never filled a transmission. What is this "going through gears" all about? Granted I am topping off, I'll probably use a quart. But there again I have no idea how much was lost.
    KOT
  10. #9
    Blayne's Avatar
    Sep 2012
    1,058
    Remove fill plug. Add oil until it comes out of the fill hole. Then start car. Fill until oil comes out again. Then put the car in gear and run it through all the gears. This ensures oil gets in all the passages and valves. Add a little more oil till it comes out of the hole. Install the fill plug with the engine running. If you turn the car off with the plug out, the oil will puke out of the hole. So install plug while running and caution......hot exhaust pipe 2" from the fill hole. I nave burns to prove it.
    P.S.....The car must be level to do this!!!!!
    Kingoftypos likes this.
  11. #10
    Apr 2009
    Ledyard, CT
    37
    9,121
    Re: Tranny Fluid?
    Thank you sir.
    KOT
  12. #11
    arogers260's Avatar
    arogers260 is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Luxury/Sport package
    Mar 2012
    Indiana
    722
    Quote Originally Posted by Blayne View Post
    I can relate to the forearm burns when I did mine. Putting that plug in will most likely get you burnt, I recommend long sleeves for that part.
  13. #12
    Blayne's Avatar
    Sep 2012
    1,058
    Quote Originally Posted by arogers260
    Next time I'm wearing oven kits lol.
  14. #13
    Z71's Avatar
    Z71
    Z71 is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    May 2005
    1,379
    Re: Tranny Fluid?
    Here is handy link where you can lookup capacities on vehicles from 1980 up... ----> Lookup Guide
  15. #14
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    Lol or some welders sleeves.
  16. #15
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    32
    7,872
    Re: Tranny Fluid?
    KOT
    i want to say that is te drain and fill amount, but total is closer to 20 if you take the pan off and start from scratch.
  17. Remove Advertisements
