3.6 CTS cranks but no start [Video Inside]
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Planktron
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 3.6 CTS cranks but no start [Video Inside] in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hello everyone My 2006 3.6 CTS cranks but doesn't start. Initially i thought it could be the fuel filter because ...
    lucaslol is offline Cadillac Owners Member
    Automobile(s): 05 CTS-V and 06 CTS
    Feb 2011
    28
    69
    Hello everyone
    My 2006 3.6 CTS cranks but doesn't start. Initially i thought it could be the fuel filter because the car had this same problem about 6 months ago and a new fuel filter got it started.
    When I push on the schrader valve in the engine bay with the green cap I get no fuel squirting out.
    I purchased a new fuel filter and when I disconnected the front of the current fuel filter in the car and turn the key it pours out fuel.
    I'm not sure if a faulty fuel filter would reduce the pressure or simply not allow any through but it doesn't seem like there's a large amount of pressure. It does however pour fuel every time I turn the key and hear the fuel pump.
    I'm including a video of what the car does when I attempt to start it. (I know towards the end it sounds like the battery is low but that's simply from cranking I'm certain that's not the problem. I'll be hooking it up to my other car when I attempt to start it again.)
    Thanks in advance!
    EDIT: I would also like to mention that the last time this happened I replaced the crank position sensor as well and that wasn't the problem.
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    393
    Re: 3.6 CTS cranks but no start [Video Inside]
    Do you have fuel pressure at the fuel rail now? It does sound "weak" cranking the engine over, make sure the battery is good and fully charged.
    Feb 2011
    28
    69
    Quote Originally Posted by ternstes View Post
    If you mean at the valve with the green cap, no. There is no fuel coming out of there. The battery has weakened from failed attempts to start it but i'm certain that's not the problem because at full charge it was still cranking the same way.
    uppercutx is offline Cadillac Owners Member
    Automobile(s): 04 CTS
    Aug 2013
    23
    15
    Might be a different issue but try removing the gas cap, flip the key over one or two times and see if you can hear the buzz of the fuel pump priming, if so, try and start it and see what it does. Also try and get ahold of a scanner to see if you have any codes stored. If your battery is good and new fuel filter and if you can clearly hear the fuel pump kick on then I would look for a no spark issue. Anything from a crank/cam sensor can cause it. If a sensor has failed the computer will not allow spark to start the vehicle to keep from damaging anything. Also check all fuses.
    Feb 2011
    28
    69
    Update: So i just got done changing the fuel filter and the car runs now. I didnt expect that to be it since i had changed the fuel filter about 6 months ago.
    Planktron's Avatar
    Planktron is offline Cadillac Owners Fanatic
    Automobile(s): 03 CTS 5M Luxury/Sport: V rear bumper and V exhaust
    Aug 2013
    Tampa, FL
    31
    172
    Glad you got it sorted, but I would look into what's molesting your fuel filters. 6 months is an awfully short life.
    Sent from AutoGuide.com Free App
    Argent1 likes this.
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    30
    1,017
    Recommended replacement for cars with a serviceable fuel filter is 15,000 miles now. It used to be every 30,000 but manufacturers now recommend 15,000 to prevent catalytic converter damage.
  10. Remove Advertisements
