Brake Lights Out .... Replace the relay? 2003 Cadillar CTS
Results 1 to 4 of 4
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Brake Lights Out .... Replace the relay? 2003 Cadillar CTS in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; None of my brake lights are working. I looked around online and found a few likely causes: BAS relay, brake ...
    tarmacjerry is offline Cadillac Owners Member
    Automobile(s): CTS
    Jan 2013
    35
    11
    None of my brake lights are working. I looked around online and found a few likely causes: BAS relay, brake light relay, brake light switch.
    Where are each of these located? What are each designed to do?
    What does BAS relay stand for?
    Whats the difference between the brake light switch and brake light relay?
    How do I change each?
    Thanks in advance. Long Live Cadillac!
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    Re: Brake Lights Out .... Replace the relay? 2003 Cadillar CTS
    when you tap the brake pedal with it in park, do you hear a click?
    Automobile(s): CTS
    Jan 2013
    35
    11
    I do hear a click when I tap the brake pedal. When I press the brake slowly and then release it I can hear two clicks, one from the brake pedal and one that sounds like its coming from the gear shift.
    Automobile(s): CTS
    Jan 2013
    35
    11
    Does anyone know if this is the brake light relay that needs to be replaced?
  7. Remove Advertisements
