headlight low beam problems
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Kingoftypos
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, headlight low beam problems in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; hey everyone, my driver's side low beam is out. took the front end apart and replaced the hid xenon bulb....didn't ...
    kevcts is offline Cadillac Owners Member
    Automobile(s): 2003 cts
    Aug 2013
    46
    5
    hey everyone,
    my driver's side low beam is out. took the front end apart and replaced the hid xenon bulb....didn't fix it. swapped the passenger side to test the new bulb(it worked) and neither bulb worked on the driver's side. checked the 20 fuses for both left and right, both good, even swapped them, both good. still no working headlight.....what next.....besides the dealer that I just got back from valve cover gaskets and they said nothing about the headlight even though I know they checked it. I keep the headlight switch on auto, and when I got the car back it was off.
    thanks kev
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    30
    1,017
    Time for a new ballast.
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,220
    They might of turned the headlights off just for going into the shop. Sometimes when putting a car on a lift, they would leave it in neutral. Thus need to turn the lights off.
    But I agree with jran, the hid ballast. First I would swap the driver and passenger around. Then order a new ballast if it follows the ballast.
    KOT.
    Aug 2013
    46
    5
    Re: headlight low beam problems
    ok thank you. however I have no idea what or where the ballast is.....
    Apr 2009
    Ledyard, CT
    38
    9,220
    You touched it when you swapped the bulbs. Well I'm pretty sure you did. The ballast is located on the underside of the headlight housing.
    KOT
    Aug 2013
    46
    5
    ok thanks. I do have moisture inside that same dysfunctional light. what are the chances that if I replace the ballast, it will go bad from moisture? am I better off replacing the whole assembly?
    Aug 2013
    46
    5
    So I took the front apart again to check the ballast.....swapped it with the other side and problem solved....almost. the bad ballast was drenched with water...pouring off. So the moisture problem is the cause. Since I had it apart, and I dont have the new ballast yet, I put some silicone around some of the edges and will wait to see if it helps before I replace the ballast. Might need a whole new housing.
    Apr 2009
    Ledyard, CT
    38
    9,220
    If it was that drenched, yeah a new housing maybe in store for you. Try finding where the moisture might of found its way in first. Seal that up and see what happens. Just make sure you don't seal up any vent holes, including from the ballast to the housing. If there are any, it's been a couple years since I took them apart.
    I know there are some in the back of the housing, they should have little one to two inch tubes attached to it with a angle downwards.
    KOT
    Aug 2013
    46
    5
    I read in some other posts about the vents. Saw them and blew in to make sure they were clear. It will be a few days before I decide which way to go, so I should see where I'm at by then. Thanks
    BmoreKi410 is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac sts
    Apr 2015
    3
    Im having a similar issue with my 2007 Cadillac sts, only my passenger side low beam is out. If it was the ballast would the high beam still come on?
    Apr 2009
    Ledyard, CT
    38
    9,220
    Quote Originally Posted by BmoreKi410 View Post
    The ballast will not affect the high beam bulbs. As they are regular halogen bulbs.
    KOT
    mattt0305 likes this.
    CaptSoloNJ's Avatar
    CaptSoloNJ is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS Lux Sport and 2014 ATS 2.0T AWD Lux
    Oct 2012
    Somerset NJ
    394
    If you had a bad ballast from moisture, and fogging inside the assembly, a dealer shop will tell you that the housing is damaged and un-repairable. They will tell you to get a whole new assembly (comes with hid lamp and ballast). Along with bumper removal and re-install , about $1,000.
  15. Remove Advertisements
