Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Seem to be lots of car problem threads...
    agp's Avatar
    agp is offline Cadillac Owners Connoisseur
    Automobile(s): Ex-CTS owner
    Mar 2009
    SE Michigan
    1,229
    I was wondering, for those who posted all the problems with error codes, vibrations, etc. What mileage is on your car? Should I be expecting my 55K 3.6L to have a problem soon?
    DavidBoren's Avatar
    DavidBoren is offline Cadillac Owners Enthusiast
    Automobile(s): Volant, VMAX, RX catch can, tranny cooler... RIP
    Jul 2012
    Portland, OR
    31
    518
    Re: Seem to be lots of car problem threads...
    There are a lot of problems posted on here because people do not run to the computer (or smart phone) just to tell everyone how freaking awesome it is to drive their CTS every day. Today, was a problem free day, car ran F-ing great, still fast, still more fun than a well-oiled midget. No, people are in a hurry to port when something unexpected happens.
    That being said, if you take care of your car, it will take care of you. Take it to a dealer, make sure any and all recall issues have been taken care of. Make sure you check the oil regularly, and add as necessary. These things drink oil. If it gets low on oil, the timing chain stretches. If the timing chain stretches, you will be in a world of $#!+.
    Regular vehicle maintenance, sir. That is all it takes to get 200,000 miles on these cars. Its not rocket science, its just common sense. Things that are common problems that I tell people to fix, even if its not broken (yet), are the PCV system, the transmission cooler, and the driveline.
    PCV system:
    Get a catch can. Any brand, as long as it has internal baffles of some sort.
    Drill out your PCV metering tube to 7/64".
    Get a breather cap for your engine oil spout.
    Transmission cooler:
    Disconnect the factory cooler built in to your radiator. The hoses/fitting are pure crap. And usually are the cause of transmission failures.
    Buy an external cooler, Hayden makes one with 1/2" inlet/outlet fittings that will match the hoses already coming out of the transmission.
    Driveline:
    Get the transmission mount reinforcement block, replace your flex discs, and get a polyurethane differential bushing... all at the same time.
    I wasnt going to really list too many specific companies, because we have some haters here, but RevShift, Creative Steel, and RX (RevXtreme) make pretty much everything you need except the tranny cooler (I know the Hayden 1240 works, and fits).
    You have a nice car. Keep it that way.
    agp's Avatar
    Mar 2009
    SE Michigan
    1,229
    One thing at a time - that checking your oil thing - if your oil is between the top two holes on the dipstick then it's okay? Or is it the bottom two?
  5. #4
    956Caddy's Avatar
    956Caddy is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac Cts Black Raven
    Apr 2012
    Harlingen,Tx
    289
    I agree take regular maintaince, Also check oil routinely and these caddy's will take care of you. Mine is at 156, 000 miles and no major issues other than replacement of water pump.
  6. #5
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    30
    1,017
    I bought my 03 with 60,000 miles and the first 15,000 was hell because original owner neglected maintenance. Since I did all of the maintenance needed and preventative it has been awesome. My car now has 125000 miles and is better now than when I bought it. First rule of thumb when owning a Cadillac is if you can't afford the maintenance, don't buy one because parts are more expensive because it is a luxury car. All the people that complain about the cost of repairs, just remember you picked the car.
  7. #6
    Jaxle67's Avatar
    Jaxle67 is offline Cadillac Owners Member
    Automobile(s): 2004 cts
    Nov 2012
    savannah ga
    95
    Jran you are 100 percent correct. Parts are really expensive. Also of you buy one and can't afford to have it properly serviced then its best to be mechanically inclined so you can do it yourself and save a ton of money. Jesse
  8. #7
    agp's Avatar
    Mar 2009
    SE Michigan
    1,229
    What are the maintenance that you guys are referring to other than changing the oil regularly?
  9. #8
    uppercutx is offline Cadillac Owners Member
    Automobile(s): 04 CTS
    Aug 2013
    23
    15
    My car had around 166k on it. Been dealer maintained its entire life. Only thing I've had to do with the car so far is clean out a clogged a/c drain line and I have a little miss I'm tracking down but that's it. This car is near perfect. Eveveryone that has seen my car has said to get rid of it ASAP because of all the troubles they have. But it just goes to show if you treat it right it will treat you right.
  10. #9
    jran0823's Avatar
    Apr 2011
    GB, WI
    30
    1,017
    Quote Originally Posted by agp
    Front end parts, fluid leaks, TIMING BELT(for the 3.2), wheel bearings, etc. Basically anything your car needs when it starts to show wear, before you have a catastrophic failure and complain you have to fix a lot more than just the part that failed because of your neglect. First rule of owning a Cadillac is preventative maintenance.
  11. #10
    Tlorenzen is offline Cadillac Owners Connoisseur
    Automobile(s): 03 CTS (Dead), 06 3.6 CTS(Sold), 07 CTS-V
    Jan 2011
    Melbourne, FL
    1,504
    I bought mine at 65k. It's now at 117k. Haven't had any problems yet. Just normal wear and tear items like filters, fluids, brakes etc. I do need to get the guibo and mounts done soon though. I've just started to get some noises/vibrations and I believe that's the problem. Motor is extremely strong though, idles nice, and still uses a ton of oil after doing the drill/breather/catch can. Oh well. I still love it.
  12. #11
    agp's Avatar
    Mar 2009
    SE Michigan
    1,229
    Quote Originally Posted by Tlorenzen View Post
    Like wear and tear in fluid pumps? What fluid can I top off myself besides the antifreeze?
  13. #12
    SHORTSTACK's Avatar
    SHORTSTACK is offline Cadillac Owners Connoisseur
    Automobile(s): 07 CTS 3.6
    Nov 2010
    York, South Carolina
    38
    1,484
    My car is maintained by myself. I do all the fluid checks, replacement etc that need to done. We have had no problems with the car at all..
    Now for all the posts that always seem to pop up. People seem to be to god damn lazy to search the facts or other threads in order to find out what the problem is. The car can be taken down to Autozone and the codes can be printed out as well with a description. Stupid stuff like , "my car wont start", i see the 5-8 of these a week. as well as what rims should i get or wheres the factory amp located. Its just stupid shit, buy a fukking manual and look it up. It get old, thats why im not on this site as much anymore. To many of the same threads posting the same things over and over. This site is by far the worst ive ever been on when it comes to people being lazy and not doing the research.
  14. #13
    Jan 2011
    Melbourne, FL
    1,504
    Quote Originally Posted by agp View Post
    You can top off or change all the fluids in your car fairly easily....brake fluid, power steering fluid, antifreeze, windshield wiper fulid, motor oil, trans fluid, dif fluid. None of them are hard to do if you have some tools.
    Quote Originally Posted by SHORTSTACK View Post
    Lol yup. I can say I've been guilty of this before haha but, some questions amaze me ha.....
  15. #14
    agp's Avatar
    Mar 2009
    SE Michigan
    1,229
    Hopefully this question isn't a common question... But are all those fluids (besides oil) universal, or are some CTS-specific?
  16. #15
    talladega's Avatar
    talladega is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS 3.6L
    Sep 2010
    Manitoba, Canada
    27
    101
    Quote Originally Posted by DavidBoren View Post
    Driveline:
    I haven't seen any threads on this (may have missed them). What is all involved in doing this? I'm making a list of different things I want to save up to do on my car in a few years and this sounds like one that would be good.
  • You may not post replies
