3.6L 05 CTS engine vibrations seen and felt inside while idle
Results 1 to 3 of 3
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 3.6L 05 CTS engine vibrations seen and felt inside while idle in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hi. I just got my car back from service where i had the timing chains replaced. the car has 123k ...
    bowser1724 is offline Cadillac Owners Member
    Automobile(s): 05 CTS 3.6, 06 DTS
    Aug 2013
    3
    Hi. I just got my car back from service where i had the timing chains replaced. the car has 123k mi. Prior to bringing it in, i did not notice anything other than the timing chain chatter. THat is now gone, but in its place is a vibration that i can feel when sitting at a stop light or in park in my driveway. When i say i can feel it, i mean if i put my knee against the door panel, or my hand on the passenger headrest. When i say i can see it, the shroud on top of the motor i can visually see it vibrating. I do not feel anything abnormal while in motion. I took a quick look but i do not see anything wrong. No engine codes, no check engine light. I called the dealer and they said this is normal for high mileage vehicles. THe problem is it was not there prior to the repair. Any advice is appreciated.
    junttiej is offline Cadillac Owners Member
    Automobile(s): 2005 SRX, 2011 CTS Sport Wagon
    Jun 2016
    3
    Re: 3.6L 05 CTS engine vibrations seen and felt inside while idle
    I just fixed mine with the same problem - new motor mounts did the trick. My symptoms were ran perfect, no codes, 160K miles, but an irritating vibration at 600 RPM - didn't matter if it was in P,N,R. Raise RPM to 700 and vibration goes away. This is an easy fix - definitely a DIY, you just need 13/16" shallow and deep well sockets and a ratchet that pivots at the head so that the bar can drop below parallel. Two nuts per mount come off easily - as soon as I took them off it was obvious that this was the problem. You also need to remove the cross bar above the engine so that you can raise the engine with a jack. This was easy on my 3.6L; took about an hour and cost me $200 (don't buy cheap Chinese mounts).
    Henryk is offline Cadillac Owners Member
    Automobile(s): 2004 CTS 3.6L V6
    Jun 2016
    3
    have the same vibrations. they are not incredibly noticeable to me really, but if i don't fix it whats the worse case scenario?
