Problem starting CTS
Results 1 to 13 of 13
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Problem starting CTS in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I've had zero problems with starting my CTS until yesterday. I parked it, didn't leave any lights on or anything, ...
    blake050 is offline Cadillac Owners Member
    Automobile(s): CTS
    Apr 2013
    17
    UnhappyProblem starting CTS
    I've had zero problems with starting my CTS until yesterday. I parked it, didn't leave any lights on or anything, and came back 30 mins later. When I turned the key, I heard a clicking/sparking sound, but the engine didn't turn over at all. Some of the interior lights came on. I let it sit overnight, and it did the same thing the next day. I kept the key turned for several seconds and after the clicking/sparking noise a few times, the engine slowly turned over and started up. I let it run for about 30 minutes, turned it off, and it did the same thing.
    I don't think there is a problem with the battery, it's less than 2 years old. Would this be a starter issue?
    A few notes: The radio is showing the battery at 14.4 or 14.5 volts. I'm not getting a Check Engine Light. When I got the car to start, the clock was wrong.
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,217
    I assume those voltage readings are when the engine is running?
    What are the voltages when it's not running?
    KOT
    Automobile(s): CTS
    Apr 2013
    17
    Re: Problem starting CTS
    When the engine is not running, it shows 10.3 volts
    josney's Avatar
    josney is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS
    Dec 2006
    South Carolina
    50
    2,299
    when mine did that, I thought maybe a starter....ended up being the battery
    956Caddy's Avatar
    956Caddy is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac Cts Black Raven
    Apr 2012
    Harlingen,Tx
    289
    10.3 sounds pretty low , mine when i check its almost always 12.5 or higher and that i know of anything less than 10.0 will enable Battery Saver Active.
    Automobile(s): CTS
    Apr 2013
    17
    The Battery Saver Active did come on when I checked the voltage when the engine was not running. I'll take the battery up to Auto Zone tomorrow to get them to check it.
    josney's Avatar
    Dec 2006
    South Carolina
    50
    2,299
    another point I would like to make blake050, I had autozone check my battery the first time also. they said everything was ok with the battery. so that is why I opted to change the starter. a couple of months went by and it started all over again, so mine was the battery all along. it just didn't show up on their initial tests. my battery was within the warranty period, so your battery doesn't have to be old to be on its way out. food for thought
    Jaxle67's Avatar
    Jaxle67 is offline Cadillac Owners Member
    Automobile(s): 2004 cts
    Nov 2012
    savannah ga
    95
    Ill agree that even though the battery showed good on the initial check does not rule it out altogether. In my experience ive had a few batteries check good on the first check only to check bad later on on the same day. Sometimes its best to check more than once before you rule it out. Jesse
    Automobile(s): CTS
    Apr 2013
    17
    The battery tested bad. New one is 180. Sucks.
    Apr 2009
    Ledyard, CT
    38
    9,217
    If the battery is less than 2 years old, then why are you paying for a new one? Don't most batteries have a 3 year 100% coverage, then 4 year 85 to 90%, 5 year 50 to 60% or something like that.
    http://www.autozone.com/autozone/par...7871_288480_0_
    That is the Duralast Gold battery from AutoZone 101-DLG. It states a 3 year free replacement and 2 year prorated.
    KOT
    Automobile(s): CTS
    Apr 2013
    17
    Thanks Kingoftypos. It's an Autocraft battery from Advance Auto Parts. I'll give them a call tomorrow to see if I can get it replaced. The only thing is I didn't buy the battery, it was already in the car when I got it.
    Apr 2009
    Ledyard, CT
    38
    9,217
    Check to see if the battery has a Manufacture's date on it. Hopefully it'll be with in 3 years, if its after then hopefully it'll be with in the prorated dates as well.
    KOT
    josney's Avatar
    Dec 2006
    South Carolina
    50
    2,299
    nailed it
    Quote Originally Posted by blake050 View Post
  16. Remove Advertisements
