Rough startup, check engine light, dim navigation
Results 1 to 2 of 2
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Rough startup, check engine light, dim navigation in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hey guys, i'm going to an autoshop after work to see what the code is and get an oil changed. ...
    foland is offline Cadillac Owners Member
    Apr 2013
    26
    Hey guys, i'm going to an autoshop after work to see what the code is and get an oil changed. I have an 06 CTS, 3.6l with 90,000 miles, my last oil change i started using penzoil high mileage oil.
    The problem either started this past week right after i didnt startup my car for a week, or right before that. It starts up rough for 5-10 seconds then seems fine, then the check engine came on today, and today for the first time the stock navigation was pretty dim for 10-15 seconds during startup.
    Anybody have an idea what it could be?
    Thanks for your help.
    Apr 2013
    26
    Re: Rough startup, check engine light, dim navigation
    The codes said i had 3 cylinders misfiring, I'n addition i have noticed lately my engine seems to get warmer than normal. I can feel more heat at my feet, though the temperature gauge is normal.
    Any ideas?
