Hi,I have a problem with my cts 3.2 exactly the mistfire 2,4,6
I changed so far spark plugs,ignition coil.
I checked the injectors,compression,timing,wires from ecm to ignition coil,everything is ok
What else check??if you had problem like me.Please help
the mistfire It happens only at low idle
I'm not from the USA
thank you
