2003 CTS 3.2 engine codes p0660c, p0153c, p0496c.. HELP!
Results 1 to 3 of 3
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 2003 CTS 3.2 engine codes p0660c, p0153c, p0496c.. HELP! in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Looking for some help on these codes. Just had a new waterpump, valve covers and gaskets, throttle body cleaned and ...
    mlp584 is offline Cadillac Owners Member
    Automobile(s): 2003 CTS
    Aug 2013
    27
    3
    Looking for some help on these codes. Just had a new waterpump, valve covers and gaskets, throttle body cleaned and new intake gaskets put on. I am getting these codes on my car when i pull them up on my dtc. Also my heat does not blow warm at all in my car. The fans and everything work fine and it switches vents fine when i turn up or down. The a/c works great.
    p0660c. When i clear the codes this always stays on. Something about the intake manifold tuning valve.. No idea what to do for this one
    p0153c. Im assuming i just need to change the driver side before car 02 sensor
    p0496c. Purge valve solenoid? My car does do the thing where when i fill up its hard to start but other than that it runs good and starts good.
    The car does idle a little rough occasionally. Really not noticeable though. Other than that it seems to run fine. Any help would be great as i dont know if these could be related somehow. Thanks in advance
    Aug 2013
    27
    3
    Re: 2003 CTS 3.2 engine codes p0660c, p0153c, p0496c.. HELP!
    bump..
    Aug 2013
    27
    3
    anyone?
