Results 1 to 12 of 12
Thread: Picked up some 20" Wheels w/pics
    DeFo is offline Cadillac Owners Fanatic
    Apr 2011
    158
    Red face Picked up some 20" Wheels w/pics
    Picked these up off CL really cheap, Chrysler 300 20" take-offs....gonna paint them black (or powder coat), and put on a set of 245/30/R20 rubber......searching for caps to replace the Chrysler logos.
    Test fit photos:
    had to clip out the reflection on that one
    I'll more upload photos after paint.....
    Feb 2012
    41
    286
    Re: Picked up some 20" Wheels w/pics
    nice any clearance problems
    SHORTSTACK's Avatar
    SHORTSTACK is offline Cadillac Owners Connoisseur
    Automobile(s): 07 CTS 3.6
    Nov 2010
    York, South Carolina
    38
    1,484
    No shyt?! I came across a set of these a while ago and the guy at the rim shop said they wouldnt fit so i didnt take a second look... Now ill definitely keep my eyes open. I really like those rims. Id get them powder coated gloss black to match the my wifes car though...
    Thats funny, i have the same jack. Why did you block your image in the paint?
  5. #4
    Apr 2011
    158
    Quote Originally Posted by ham4864 View Post
    Not sure yet on all clearances, these tires are too big to drive with (would probably be OK in the rear, but the front would surely rub while turning).....should be fine with 245/30R20's.
    The wheel has the same 5x115 bolt pattern, and the bore is a few mm bigger than the CTS hub, the offset is higher than the OEM CTS wheel, as the 300 wheel sticks out further and is much more in-line, with the fender area.
    Quote Originally Posted by SHORTSTACK View Post
    I'll be painting these black.
    As for the reflection, the Mrs did not want to be in the photo.
  6. #5
    SHORTSTACK's Avatar
    Nov 2010
    38
    1,484
    Good choice. I understand about the wife. Mine would say the same.
  7. #6
    Pete(UK)'s Avatar
    Pete(UK) is offline Cadillac Owners Fanatic
    Automobile(s): CTS 2007 Sport Luxury
    Mar 2013
    London, England.
    128
    Quote Originally Posted by DeFo View Post
    Especialy as she was naked. LOL
  8. #7
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,461
    Those are really sharp looking! I'm interested to see a shot of the whole car once you get them mounted. Personally I think they would look better if you kept them silver - painting them black just makes them disappear, so you lose the effect of having nice looking wheels (IMO).
    The wheel has the same 5x115 bolt pattern, and the bore is a few mm bigger than the CTS hub, the offset is lower than the OEM CTS wheel, as the 300 wheel sticks out further and is much more in-line, with the fender area.
    Higher positive offset would suck the wheels in. Lower positive offset pushes them out. The intarweb says the specs on those wheels is 20x8" +24mm, which means they sit out ~3/4" farther than the 12-spoke 18" wheels that came on the Sport package cars (those are 18x8" +44mm).
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  9. #8
    Apr 2011
    158
    Quote Originally Posted by AAIIIC View Post
    You are correct about the offset...it is lower.....also my OEM wheels are 17"
  10. #9
    AAIIIC's Avatar
    Aug 2007
    6,461
    I was just using the Sport wheels as an example, since they're also 8" wide and thus you can easily compare the offsets.
  11. #10
    Apr 2011
    158
    I want to find some hub-centric rings, but the tolerance may be too tight.
    CTS center bore = 70.3mm
    300 center bore = 71.5mm
    Just found some!....will order them up, and update everyone later.
  12. #11
    Apr 2011
    158
    UPDATE:
    Wheels are on....finishing up the Caddy center caps tonight...will post more soon.
  13. #12
    HtownV04 is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Feb 2012
    5
    Did you still use 245/30 size tire? Any suspension mods?
  • You may not post replies
