Read differential bushing - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Like Tree6Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Read differential bushing in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; How does the 80A blue bushing feel? Any added noise or vibrations? Im considering ordering one within the hour...
  1. #16
    jeffao is offline Cadillac Owners Member
    Automobile(s): 2004 cts
    Jul 2013
    26
    27
    Re: Read differential bushing
  2. #17
    DavidBoren's Avatar
    DavidBoren is offline Cadillac Owners Enthusiast
    Automobile(s): Volant, VMAX, RX catch can, tranny cooler... RIP
    Jul 2012
    Portland, OR
    31
    518
    RevShift, let me apologize. I have seen your BMW headers on your website and was truly amazed at the craftsmanship. I stand corrected... opens mouth, inserts foot.
    Bluehaze07 likes this.
  3. #18
    ham4864 is offline Cadillac Owners Fanatic
    Feb 2012
    41
    286
    I installed the red one and i don't notice vibration.
  5. #19
    454Casull is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS 2.8L 6MT
    Apr 2010
    406
    I installed the CS bushing and it works fine.
  6. #20
    Kilowatt is offline Cadillac Owners Member
    Automobile(s): CTS
    Jun 2013
    Kansas
    52
    15
    Greetings guys,
    I've been following this thread and I must admit I'm a noob with the CTS. (my 1st caddy - really like this model, they are well designed)
    I obtained a 2005 plain-jane CTS a couple months ago and amongst its nuances is a clunk in the drivetrain when accelerating/decelerating. When I was changing the tranny fluid and filter I inspected the rubber bushings at either end of the drive shaft and observed cracks in the rubber around the fasteners. I suspect this is causing the clunk, also having vibration at speeds above 45mph...am I on the right track here?
    I'll check out the two vendors mentioned here that provide parts. I have the OEM manual set so I have a procedure for the swap (havent reviewed it yet) but it looks like the exhaust system has to be removed to access this...my specimen has dual exhaust.
    Any tips and guidance appreciated.
    Thanks!
    kw
  7. #21
    Feb 2012
    41
    286
    I didn't have to remove the exhaust.
  8. #22
    Apr 2010
    406
    Quote Originally Posted by Kilowatt View Post
    Greetings guys,
    Thanks!
    kw
    In my experience, the biggest cause of clunking was the front bushing on the differential. The worn giubo joints (flex discs) contributed strongly to noise and vibration but the jarring feeling was less, compared to the bushing.
  9. #23
    briggy's Avatar
    briggy is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 3.6L 2005 80,000 Miles
    Dec 2009
    Southern California
    41
    958
    I'm looking into doing this repair. Having done the bushing replacement on my mitsubishi I know what a royal pain this can be. Then I used a torch to burn out the bushing then used a hack saw to saw out the casing. The nice thing is it looks like the rev shift tool doesn't have to be pressed in, on the other note CS has the tool for $30. I noticed the bushing is listed as a CTS-V bushing is this interchangable with the CTS 05 bushing. Also whats the outside diameter on teh casing if I shoudl decide to make my own tool. Last question is has anyone notice the revshift bushing squeaks after a while when the lube dries out ? I ran into this problem on my other car, keeping in mind these were the a-arms
    thanks,
  10. #24
    Revshift is offline Cadillac Owners Fanatic
    Automobile(s): none
    Apr 2011
    Warren, MI
    258
    We use an air hammer to get the old bushings out. It works good and is pretty quick.
    The lube that we supply with our bushings is energy suspension's formula 5 prelube. It is formulated for polyurethane. We have never seen it dry out.
  11. #25
    voodoochikin04 is offline Banned
    Automobile(s): 2003 cts, 2004 Cts-v
    Nov 2012
    Norfolk, NE (eastern Nebraska)
    31
    316
    The lube that comes with revshift bushings appears to be good stuff. Imagine really thick vaseline mixed with glue... its thick, its sticky, and it works great on the poly bushings.. Hope that eases some minds.
  12. Remove Advertisements
