2003 CTS Misfire Problems
Results 1 to 4 of 4
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 2003 CTS Misfire Problems in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Problems solved. Please delete thread....
    Nasty CTS is offline Cadillac Owners Member
    Automobile(s): 2003 CTS/ 2010 CTS-V/ 2007 Z06
    Feb 2012
    Arizona
    71
    QuestionCTS Misfire Problems
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    35
    717
    Re: 2003 CTS Misfire Problems
    Without knowing the history of the car, new plugs and then new coil set if the idle continues to be erratic.
    the P0300 2 4 and 6 are all related to #2 #4 #6 cylinders, which means one of your coil set is likely bad, they come in a pack of 3 per side.
    It can also relate to bad spark plugs.
    If it were me id do both coils and new plugs, no sense in leaving old stuff on one side for it to be stressed more than the new stuff.
    Feb 2012
    Arizona
    71
    Fixed. Valve cover gaskets and all that done, problem killed the coil pack, so I did those and the plugs while I was in there. Runs great now.
    arogers260's Avatar
    arogers260 is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Luxury/Sport package
    Mar 2012
    Indiana
    722
    Best do the pcv upgrade or those vcgs will fail again and the spark plug wells will fill with oil again also.
  7. Remove Advertisements
