Rear jacking points
Results 1 to 9 of 9
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Rear jacking points in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I'm going to change out my fuel filter in a week or so. It's located right where a jack would ...
    holsgo is offline Cadillac Owners Fanatic
    Automobile(s): 2007 cts
    Apr 2011
    143
    Rear jacking points
    I'm going to change out my fuel filter in a week or so. It's located right where a jack would be, in front of the passenger side rear wheel. So, I'm looking at other jack stand points under the rear so I can get to the filter while gaining a bit of clearance.
    I'll jack it from the pinch weld point right in front of the rear passenger tire, then place a stand. Which spots have you guys used? I numbered some areas in these pics and I don't want to jack or stand on the diff. Thoughts?
    Blayne's Avatar
    Blayne is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS sport model/package
    Sep 2012
    Sudbury, Ontario Canada
    1,058
    Where you have the arrow in the third pic is exactly where I put my stands. The top of my stands are just wide enough so that the frame part sits just inside the lip on the outside edge of the stand. Never had any problems there.
    Apr 2011
    143
    Re: Rear jacking points
    That spot looked awfully appealing so I'm happy to confirm. Thanks.
    poncho89 is offline Cadillac Owners Member
    Automobile(s): 2005 CTS- V
    Jul 2012
    Norfolk, VA
    48
    Kind of unrelated, but I noticed from the pictures that you have Hankooks on your car. How do you like them? I have the V2 Concepts and while the ride and the traction are great I noticed they rumble alot after 75 MPH, whats your experience?
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,220
    Any of the spots you've indicated in the pics will work just fine. So would the diff, for that matter - there's no reason to be worried about putting a jack or stand on the diff. For what you're wanting to accomplish, though, I would say one of the two rear subframe locations you identified would be the smartest choices, as they'll keep the car up higher.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    Problem solved
    We had old rusty beat steel ones. Our Caddy's could not get on them without blocking.
    Found a set of low rise plastic ones and have been thrilled since.
    About the price of a cheap set of jack stands.
    Lite - fast deployment - safe - no rust - store easy enough.
    Apr 2011
    143
    I do have a set of ramps, but they would be in the way. If I backed the car onto them, the lowest portion of the ramp would be right where I will be laying. Not too comfortable of a place to lay, right on top of the raised portion of the ramp.
    The hankooks are fine. I haven't really noticed a difference to be honest. I have continentals as well and they make no more noise than others. But I don't drive the hell out of the car either.
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,149
    I've never had to jack up a car to change the fuel filter, but I've yet to change it on the CTS. I also hate jacking up unibody cars. hehe.
    Apr 2011
    143
    I do hate jacking unibody as well. Takes me a minute to think through the right points. It's not that you can't get your hands on the filter without the lift. Just hat you'll find it hard to break the quick disconnects free without some working room.
  12. Remove Advertisements
