Key fob weak
Results 1 to 15 of 15
Like Tree2Likes
  • 2 Post By Pwayne
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Key fob weak in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; howdy , recently i've been noticing my keyfob not working as far as it used to , so i replaced ...
    956Caddy's Avatar
    956Caddy is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac Cts Black Raven
    Apr 2012
    Harlingen,Tx
    289
    Key fob weak
    howdy , recently i've been noticing my keyfob not working as far as it used to , so i replaced my battery on key fob cr2032
    and it worked for a while but decrease in range quickly. My question is does anybody know where the transmitter for key fob
    is? How can i get better range? Thanks in advance
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,215
    Re: Key fob weak
    The transmitter is obviously in key fob. However, the receiver is the same module that is used for the FM antenna as well as the Tire Pressure Sensor, if you have the sensors installed in the wheels.
    KOT
    956Caddy's Avatar
    Apr 2012
    Harlingen,Tx
    289
    your clear up taught me something, I meant receiver in the car. Also Im suggesting that it might be the door lock actuators because I can click open x amount of times and only passenger side opens and once in a while the drivers and rest or doors will work on response.
    Apr 2009
    Ledyard, CT
    38
    9,215
    Re: Key fob weak
    Just for ha ha's. Start your car and open one door at a time. Does the radio display the correct door? It should say "Driver's door open." "Front passenger door open" and so on.
    KOT
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    35
    717
    Re: Key fob weak
    Try a round bandaid behind the non contacting part of the battery on the fob, i found mine was a bit hit and miss at times and this helped till i replaced the casing with a new one, if you cant find the caddy specific fob casing (like i couldnt) the generic gm ones will fit if you sand a little away from the edges of the pcb board, not to much though, you dont want to be cutting into any of the traces on the board and breaking circuits!
    TomV is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac CTS 2003
    Aug 2006
    Annapolis, MD
    144
    Re: Key fob weak
    For my 2003 the receiver module is under the rear deck in the trunk. Check that it is still clipped to the deck. If you knocked it off accidentally it may be floating around and the antenna may be lower than necessary for adequate range. With my setup and a clear, unimpeded view of the car I can get at least 150 feet of range.
    Pwayne is offline Cadillac Owners Fanatic
    Jun 2008
    185
    Re: Key fob weak
    I have a similiar problem, mine is hit and miss. When it works, the range is very good. But often it doesn't work at all, even if I am fairly close to the car. I hit the button over and over, and after many tries it may decide to open, sometimes not. Then all of a sudden it will work good for a time or two, then start messing up again. I have tried new batteries 3 times, and it doesnt seem to help.
    956Caddy's Avatar
    Apr 2012
    Harlingen,Tx
    289
    Quote Originally Posted by Pwayne View Post
    Same with me, its annoying cause if I'm in a rush and it doesn't work I have to use the key to enter or walk around the damn car to open up
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,687
    Re: Key fob weak
    Hello Pwayne,
    I am sorry to hear that you are experiencing an issue with your Key Fob. Private message us if we can be of assistance.
    Regards,
    Jennifer T. (Assisting Laura)
    Cadillac Customer Care
    Jun 2008
    185
    Re: Key fob weak
    OK I think I fixed mine.
    In the past, I would either just replace the battery, or clean the area where the battery makes contact.
    Than never helped any.
    This time I pulled the circuit board completely out. On the side of the circuit board that you DON'T see when you split the FOB case to open it up, there was trapped moisture and some black gook, maybe mold, in there.
    So I cleaned up that side of the circuit board and the FOB case, and its working good now.
    Hope this applies other people having similar issues.
    CTSjones and MIKEPULL like this.
    98Catera_2010's Avatar
    98Catera_2010 is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Cadillac Catera Sport
    Oct 2010
    Cookstown, Ontario Canada
    28
    242
    I just did what you suggested for my 98 Catera key fob I had something wet inside as well so cleaned it up and now it back working like it should and not only when beside the car.
    Jun 2008
    185
    Re: Key fob weak
    Looks like this may be the cure for many of us then.
    MIKEPULL is offline Cadillac Owners Member
    Automobile(s): 2008 CTS4
    Apr 2012
    47
    5
    Re: Key fob weak
    I too have been experiencing this issue and did what you suggested, and so far so good. (fingers crossed)
  16. #14
    DavidBoren's Avatar
    DavidBoren is offline Cadillac Owners Enthusiast
    Automobile(s): Volant, VMAX, RX catch can, tranny cooler... RIP
    Jul 2012
    Portland, OR
    31
    518
    Re: Key fob weak
    Get an aftermarket alarm with a better remote. And by better, I mean anything that works. Even if the signal sends on the first time you fully press the button, you still have to fully press the button again to unlock each individual door. Stupid. The "UNLOCK" button should unlock every door at the same time, just like the "LOCK" button.
  17. #15
    buffalobarnes Guest
    Re: Key fob weak
    I followed your suggestion for my weak key FOB for a 2005 Cadillac CTS that I just purchased used. Now it works great. Thanks!
  18. Remove Advertisements
