Tune up in a 2004 CTS 3.6 L
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By AAIIIC
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Tune up in a 2004 CTS 3.6 L in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hello, does anyone know how often should a tune up be done in a 2004 CTS. I've had the care ...
    tito082 is offline Cadillac Owners Member
    Automobile(s): 2004 CTS 3.6 L
    Jul 2013
    Los Angeles, CA
    5
    Hello, does anyone know how often should a tune up be done in a 2004 CTS. I've had the care almost 5 years and I have not done a tune. Any suggestions? Also, how should a transmission fluid changed or flushed?
    Thanks
    silver_viper_tb is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac CTS
    Dec 2012
    33
    7
    Re: Tune up in a 2004 CTS 3.6 L
    I replaced the plugs in my 05 CTS recently , I went with the Iridium plugs from AC Delco. from what I understand these plugs are supposed to be platinum plugs from the factory. From the dealers I've worked for rule of thumb for platinum plugs is usually 90k miles. however I like to replace them sooner. I may be doing them too often but I like every couple of years. even with iridium/platinum plugs. cheap to do and keeps things running smoothly.
    Jul 2013
    Los Angeles, CA
    5
    Thanks. Would you have to know of a "how-to" website on how to change the spark plugs on my 2004 CTS?
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,393
    The term "tune up" is a bit out of date, as there's really nothing that needs to be "tuned up" on a modern car. However, there are routine, periodic maintenance items that should be taken care of. How many miles are on the car, and how many miles have you put on it in that 5 years? In that 5 years has anything other than oil changes and tire rotations been done? Brake fluid flush and bleed? Coolant flush and fill? Fuel filter replacement? Air filter replacement? Cabin air filter replacement? Etc etc...
    If you have an Owners Manual the periodicity of that sort of stuff will be covered. If you don't have one, it might be worth getting one, or seeing if the local dealer will give you a copy of the maintenance schedule.
    Quote Originally Posted by tito082 View Post
    You can search here and find some "how to" threads, like this one.
    Argent1 likes this.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  7. Remove Advertisements
