HID blinking out momentarily, then back on... but only when I make hard right turns!
Results 1 to 12 of 12
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, HID blinking out momentarily, then back on... but only when I make hard right turns! in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; So, I've had my '05 CTS High Feature for a couple years, and it has always had an issue with ...
    ScotchNSodie is offline Cadillac Owners Member
    Automobile(s): '05 CTS High Feature
    Dec 2011
    8
    So, I've had my '05 CTS High Feature for a couple years, and it has always had an issue with the left headlamp blinking out for a second during really hard right turns (though not every time, and weather/temp seems to have no effect), then it comes back and all is well.
    I've considered looking into it, but it seems the HIDs are a pain to work on, so I figured I'd wait until they croaked. Well, the other night I made a hard right turn and the left lamp went out... then it stayed out... for a couple minutes. I figured it's telling me that I can't procrastinate on this any longer. Do you think it's just a loose connection at the ballast, or what? I see no evidence of water intrusion in the lamp housing, but maybe I just can't see it.
    Is there some specific thing that I should be looking into first? I searched for a similar problem here, but found nothing. Then, that's the way it usually goes: I have a problem no one has ever heard of before. lol
    Thanks,
    ~S~
    '05 CTS 65K miles
    arogers260's Avatar
    arogers260 is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Luxury/Sport package
    Mar 2012
    Indiana
    722
    Quote Originally Posted by ScotchNSodie View Post
    Thanks,
    ~S~
    '05 CTS 65K miles
    I had a similar issue that KOT helped me solve. Try switching the bulb to the other side (its a pita) and see if it stays with the bulb. Mine did so I replaced the bulbs and the flickering stopped no problems since.
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,123
    How are are your bulbs, OP?
    If they came with the car. Then if I were you, I would replace the bulbs anyways.
    KOT
  5. #4
    Dec 2011
    8
    Re: HID blinking out momentarily, then back on... but only when I make hard right tur
    Thanks, guys. I think I'll just replace the lamps (might as well do them both, right?) and we'll see how it goes. D1S is the replacement part, correct? Is there a favored color temp and brand? I'm not looking for some silly blue light, I just want ideal performance without blinding oncoming traffic.
    Thanks again!
    ~S~
  6. #5
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    Thanks again!
    ~S~
    Yes replace in pairs is the best idea. As far as temp i don't even know what I put in. D1s is correct, I got mine at autozone and I think they were sylvania's. I lost a bit of the blueish tint from the stock bulbs with the ones from autozone but I don't mind them, they work just as good.
  7. #6
    Matt4949 is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS 3.6 Black/Black (Sold); 05 CTS-V Black/Black
    Aug 2010
    CT
    31
    124
    Sounds like a loose electrical connection to me. Honestly, you should go through and check everywhere something is plugged into something else.
  8. #7
    Dec 2011
    8
    Quote Originally Posted by arogers260 View Post
    I'm not all that concerned with temp. I thought that stock was something like 4500K, but I'm not sure. I'll research it before I buy replacements; the OEM temp is perfectly fine in my opinion.
    Quote Originally Posted by Matt4949 View Post
    That's what I thought, too. I will look for loose connections if I can see them without tearing the car apart. But if I have to start taking this sucker apart, I'm going to replace the bulbs while I'm in there and hope that was the fix. Modern cars are a PITA.
  9. #8
    Apr 2009
    Ledyard, CT
    37
    9,123
    If I recall correctly, 4,300K is factory. But good luck in finding that, besides 4,500K as you mentioned, is perfectly fine and probably not that much of a difference.
    KOT
  10. #9
    Blayne's Avatar
    Blayne is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS sport model/package
    Sep 2012
    Sudbury, Ontario Canada
    1,058
    Yes stock is 4500K. 6000K is pretty much as clear white as you will get before it starts to go blueish. I have 6000K headlights and fog lights and it is crystal clear and bright as all fawk, and never had one person flash me.
  11. #10
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    29
    1,017
    OE temp is 4300k
  12. #11
    Blayne's Avatar
    Sep 2012
    1,058
    Quote Originally Posted by jran0823
    OE temp is 4300k
    Thanks for the correction, I knew it was around there ;-)
  13. #12
    Dec 2011
    8
    For some reason, I never answered this question. Sorry about that. Anyway, in the year since I posted this, I never got around to replacing the bulbs because it just doesn't quite *feel* like a bulb issue, and the problem hasn't worsened. At ten years old and 76K miles, I suppose I could replace them just to whittle things down... or find a lose, rubbed wire in the process of replacement.
    Thanks again, folks!
    Quote Originally Posted by Kingoftypos View Post
    KOT
  14. Remove Advertisements
