Question about tires / rims
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 4 of 4
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Question about tires / rims in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; So stock rims and tires on my 04 CTS are 225/55/16 tires with a 5 bolt 115 mm offset on ...
    RJC
    RJC is offline Cadillac Owners Member
    Automobile(s): 2004 CTS
    Jul 2013
    26
    1
    So stock rims and tires on my 04 CTS are 225/55/16 tires with a 5 bolt 115 mm offset on the rims. Correct me if im wrong.
    Found a pretty good deal on some 18 inch rims, 5 bolt 114.3 mm offset and 235/45/18 tires.
    As far as I know, these should fit my car fine without any issues. I just wanted to make sure before I spend the money, can anyone confirm this for me?
    Thanks
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    4,479
    Re: Question about tires / rims
    What width? Offset? Hub bore?
    Wrong bolt pattern?
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    MoistCabbage's Avatar
    MoistCabbage is online now Cadillac Owners 10000+ Posts
    Automobile(s): Crimson 2001 Seville STS, 1990 Seville (RIP)
    Sep 2010
    East Boston MA.
    27
    23,882
    Yes, wrong bolt pattern. Not "close enough". When the lug nuts are torqued, all of the hardened (read: fairly brittle) studs are being bent inwards. At the same time, the lug seating surfaces are getting galled.
  5. #4
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,522
    The term "5x115mm offset" is wrong. Offset has nothing to do with bolt pattern diameter. The wheel width and relation to hub face is used for offset comments.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
