Anyone run spacers on stock wheels?
Results 1 to 5 of 5
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Anyone run spacers on stock wheels? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Just as the title says, has anyone run spacers on first gen cts with stockers? I'm looking get the rear ...
    johnladow07 is offline Cadillac Owners Member
    Automobile(s): 2007 CTS 3.6
    Mar 2013
    46
    Just as the title says, has anyone run spacers on first gen cts with stockers? I'm looking get the rear wheels/tires to sit more flush with the fender. At the moment I'm running the 12 spoke 18x8 chrome wheels with 255 45 18 tires. I have no plans to lower it and the car has fe5 package if that matters. Best place to get the spacers? What would be the best size?
    GreekMavro is offline Cadillac Owners Member
    Automobile(s): 2004 CTS
    Nov 2012
    New Jersey
    3
    Re: Anyone run spacers on stock wheels?
    I was thinking about spacers for my car but im not sure how it would look on our cars would like to see a picture if anyone has it.
    DavidBoren's Avatar
    DavidBoren is offline Cadillac Owners Enthusiast
    Automobile(s): Volant, VMAX, RX catch can, tranny cooler... RIP
    Jul 2012
    Portland, OR
    31
    518
    Of course having the tires/wheels flush with the fender would look good. I dont even know if there are 5x115 spacers, though. I was wrong, here is a link:
    http://www.motorcitybolton.com/wheel...l-spacers.html
    I saw someone selling a set of modified stock Vee rims with 11mm spacers once. The rims were modified so that the rear wheels were up front and the fronts had been widened 2" for use in the rear. They said the 11mm spacer was perfect.
    Hope that at least helps give you an idea.
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,312
    Quote Originally Posted by johnladow07 View Post
    Since you're doing this for aesthetic reasons, the best size is entirely up to you - none of us can tell you what you want the car to look like. Go out to your car with a tape measure and see how much farther out you would like the wheel/tire to sit. There's your spacer size. Or take a wheel off, slip some washers over the studs, bolt the wheel back on, drop the car off the jack, see how it looks, repeat until you get desired look and then measure the stack of washers.
    There are limitations based on wheel stud length and lug nut thread engagement; beyond a certain thickness you would need to use a bolt-on spacer vice a slip-on spacer. And bolt-on spacers only come in certain thicknesses, and the back of the stock wheels may not allow fitment of the bolt-on spacers. But all of that is true regardless of what car you're putting them on, so you probably know all of that already.
    http://www.motorsport-tech.com/ is one example. You can find others online.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    AlpineCTS is offline Cadillac Owners Member
    Apr 2013
    78
    **** that i just put 1 inchers in front and back which is 25mm they are great on amazon 110 for all 4 billet. Honestly one would be happy with a 20mm in front cause my front tire is a cm or so past my fender and no rubbing. Rear tire is a fuzz past flush with fender i would say 1 inchers are a good look though all around with the stock 17s. I just need to get it lowered i already got my mighty mouse mod sitting here.
    Would like to point out the spacers i mentioned on amazon search "cadillac cts 5x115 wheel spacer" and you should see it they make 1 and 2 inchers. These are perfectly bored for the 04-07 cts to 70.3mm or whatever and a really snug fit. I think i either need new lugs or a skinny socket of some sort though.
  8. Remove Advertisements
