technical problem
Results 1 to 5 of 5
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, technical problem in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hello guys! need a little help! I replaced the both cylinder heads on the LA3 engine, and now I can ...
    Aisberg is offline Cadillac Owners Member
    Automobile(s): CTS 2003
    Apr 2013
    Russia Siberia (Irkutsk)
    11
    technical problem
    I replaced the both cylinder heads on the LA3 engine, and now I can not find where to connect this plug!
    I removed the intake manifold and checked the Cooling bridge and everything i could get! I know it's my fault - you need to label all that you remove ...But maybe somebody has a drawing?
    This connector can be somehow affect the fans? after I assembled the engine, they do not work.
    thanks in advance.
    Apr 2013
    11
    Re: technical problem
    krusty_tc is offline Cadillac Owners Member
    Automobile(s): 2003 CTS Luxury Sport
    Apr 2013
    52
    51
    Aisberg, I just did my timing belt. By where that plug is situated, could it plug into the back of the upper air intake manifold. I believe there was a plug on the back of that.
    Dave
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    35
    717
    the good thing about wires is they are only made to stretch as far as they are supposed to fit, so look around the area that it will stretch too, you'll find the hole
    Might be the switchover solenoid plug on the back of the upper intake, this may help: https://docs.google.com/file/d/0Bz8m...it?usp=sharing
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    30
    1,017
    By the looks and position of that plug it could be crank shaft position sensor.
  8. Remove Advertisements
