Water leaking under glove box please help!
Results 1 to 4 of 4
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Water leaking under glove box please help! in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I have a 07 cts 3.6 and when I use my ac there is water leaking under the glove box ...
    raven07cts is offline Cadillac Owners Member
    Automobile(s): 2007 black raven cts 3.6
    Apr 2013
    I have a 07 cts 3.6 and when I use my ac there is water leaking under the glove box on to the passenger floor. It only happens when the ac is on. I took the plastic piece off under the glove box and couldn't find a leak in anything. Please help!!!!
    arw1510 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS 3.6, 2004 SRX 4.6 AWD, 2012 CTS 3.6 DI AWD
    Oct 2008
    1,229
    Quote Originally Posted by raven07cts
    Post in the cts forum and someone should be able to help
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,697
    Re: Water leaking under glove box please help!
    Quote Originally Posted by raven07cts View Post
    Hello raven07cts,
    I apologize that you have water leaking into your passenger area when the AC is on in your CTS. Have you thought about taking your vehicle to the dealership to see if they would be able to diagnose what is causing this? If you would like any assistance in working with the dealership, please private message me. I would need your name, contact info, VIN, mileage, and dealership you would like to work with. Thank you very much for your time.
    Gregory W.
    Cadillac Customer Care
    jcornv15's Avatar
    jcornv15 is offline Cadillac Owners Member
    Automobile(s): 2007 CTS 3.6 Base
    Jul 2013
    San Fernando, Ca
    30
    38
    You have a clogged vent tube. It stems from the condenser and dives down towards the gas pedal under the carpet exiting above the transmission on drivers side. Either pull back the carpet next to the pedal and pull the hose(water will go everywhere) or try to find it behind the trans and heat shielding under the car. You will need to clean out the blower. The water your getting is inside the fan assembly and could turn into mold if not dried up. Probably about a cups worth. Hope this helps
    Generally poking the tube clogging with a coat hanger or long screwdriver gets the clog cleared. I have the exact same car and model and just did this job.
  7. Remove Advertisements
