Cannot close air box properly after taking it out for engine air filter replacement
Results 1 to 7 of 7
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Cannot close air box properly after taking it out for engine air filter replacement in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I am trying to replace the engine air filter on my 2006 CTS 2.8. I get the FRAM air filter ...
    modelcitizen is offline Cadillac Owners Member
    Nov 2012
    13
    QuestionCannot close air box properly after taking it out for engine air filter replacement
    I am trying to replace the engine air filter on my 2006 CTS 2.8. I get the FRAM air filter and unscrew the 2 screws on the top of the air box to separate the two parts. Instead of letting the bottom of the box still attached, I completely detached the two parts. The attachment of the bottom was made by 8 feet that insert into 8 slots. The problems is after I place the new filter and want to put the air box part to the original place, there is no way I can get those feets and slots re-engaged at the bottom no matter how hard I try.
    Have you guys ever experienced that?
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,302
    Re: Cannot close air box properly after taking it out for engine air filter replaceme
    Yup, there have been plenty of people doing that. You just need to figure out how to put the legs back into the slots. Try it with the filter out, if that doesn't work detach the hose leading to the TB. Or remove the entire filter housing.
    KOT
    arogers260's Avatar
    arogers260 is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Luxury/Sport package
    Mar 2012
    Indiana
    722
    Quote Originally Posted by modelcitizen View Post
    I did this too and kept getting p0171 and p0174 error codes. I took the box completely our and reassembled correctly then put it back in. Problem solved
    leikas57 is offline Cadillac Owners Member
    Aug 2013
    Quote Originally Posted by arogers260 View Post
    Hello, I am having the same problem as you - I can't get the little hooks back into the holes to keep the air filter and housing attached. Did you take out the piece with the holes and insert it? How did you (or anyone else) manage to get this bugger back in?
    Thanks guys
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    35
    717
    I always take the whole box out when I change the filter, gives yo loads of room to get the hooks back in place
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    Quote Originally Posted by leikas57 View Post
    Thanks guys
    Exactly what ctsuk said take out the whole box. T here's only three screws and the hose clamp attached to the maf sensor. Once the box is out you should have no problem at all.
    Aug 2013
    Thanks guys, worked like a charm! Guess I thought there were way more things attached to the air box than there were!
  10. Remove Advertisements
