Car stops while driving, with codes 341 & 335
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By curtc
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Car stops while driving, with codes 341 & 335 in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hello everyone. I'll try to keep it detailed and short! This may seem like obvious for most of you'll but ...
    Keviardi is offline Cadillac Owners Member
    Automobile(s): 2013 white diamond, Premium CTS Coupe
    Apr 2012
    Dallas, Texas
    29
    79
    This may seem like obvious for most of you'll but I'm a sucker for saving money and fix what I need and not isn't needed.
    So drove around 45 mph yesterday and the car stops. Eventually I could restart it. It scared me because I had this problem before I replaced my ECM last year. But I have codes PO 341 twice, (may just be my reader.) and PO 335.
    At this point what is it I need to fix, and what's the best order of doing so if it's multiple problems? (crankshaft/cam shaft )
    Thanks for any help guys!
    P0341 - Camshaft Position Sensor Circuit Range/Performance
    P0335 - Crankshaft Position Sensor A Circuit Malfunction
    - thanks curtc
    Argent1's Avatar
    Argent1 is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,937
    Re: Car stops while driving, with codes 341 & 335
    What are the codes for ?
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    Keviardi likes this.
    propninja's Avatar
    propninja is offline Cadillac Owners Fanatic
    Automobile(s): CTS
    Jul 2005
    Los Angeles
    178
    replacing the sensors will solve your problem. crankshaft position sensor is right above the oil filter. You'll need a t-8 torx socket to remove it. I haven't had to replace the crankshaft sensors so I can't speak to that, but I wouldn't wait to replace that crankshaft sensor, it's given about all of the warning you're going to get.
    Apr 2012
    Dallas, Texas
    29
    79
    Do you think replacing the crankshaft would do the trick? Talked to a mechanic And he says I need to replace both, but I just think its weird both went bad at the same time.
    s_tharsan's Avatar
    s_tharsan is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS Sport
    Aug 2009
    Toronto, ON
    29
    260
    I had a camshaft position sensor error come on and replaced it and still had the same issue. Check your oil level. That's what was setting of the sensor for me, it was too low.
    Apr 2012
    Dallas, Texas
    29
    79
    Interesting take! I've gotten over 3000 miles for the typical oil change due date on the sticker. I usually put in a little more. I'll get an oil change and see where that takes me. Thanks.
    s_tharsan's Avatar
    Aug 2009
    Toronto, ON
    29
    260
    Your don't need to do an oil change. Just check the dip stick. Its just an idea, may not be the case.
  11. Remove Advertisements
