how can I fix my dic screen?
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By DopeEffect
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, how can I fix my dic screen? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Been through a lot of crap with the dic and my stereo shop. Well I got the screen working but ...
    pinspade's Avatar
    pinspade is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac CTS 3.6 liter
    Aug 2012
    perris, ca
    189
    Been through a lot of crap with the dic and my stereo shop. Well I got the screen working but it's very dim as if the bulbs are burnt out.
    Any idea how I can fix it?
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Replace the smleds
    Not easy
    cabletech is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS 3.2L M35 LtPt
    May 2010
    223
    Re: how can I fix my dic screen?
    What did the stereo shop do? Did you add an aftermarket head unit in the CD changer location?
    I've worked on my DIC (changed it to blue), replaced the LEDs, etc. Only issue I had was when opening up the circuit board for the head unit, I cut some traces that killed the lights on the right side knobs (I had to go back in with some small wires and rebuild the traces). I don't know what they may have done to make it 'dim', unless they cut a trace they shouldn't have.
    The 'don't fix the problem' method would be to replace the resistors, not LEDs. I replaced my resistors first with 330 or 470 ohm (don't remember), and the DIC was too bright. I eventually ended up with the stock resistors back in there.
    DopeEffect's Avatar
    DopeEffect is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 3.6L CTS, Hotchkis Sway Bars, FE2
    Jul 2012
    Dallas, TX
    27
    524
    No offense but I thought it'd go ahead and throw this out there. Did you check to make sure the light dimmer on the ceiling isn't set to the lowest setting. I made that mistake one day. Thought all my dash lights burned out, flipped the **** out for a few seconds then checked the dimmer. It was set all the day down. Pretty embarrassing to be honest but I thought it was funny.
    kylebooth likes this.
    pinspade's Avatar
    Aug 2012
    perris, ca
    189
    Quote Originally Posted by cabletech View Post
    Well they followed the thread "retain dic" and something went wrong obviously. The screen is dim as if there are no lights.
    I will read that thread you mentioned. Is there a way to find out if it's the resistors or LEDs?
    Quote Originally Posted by DopeEffect View Post
    -_- of course I checked the dimmer. The dimmer would not shot the lights off completely. Only make it Dim.
    The dimmer switch does adjust the brightness of the dash and ac screen but doesn't affect the dic.
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,221
    Since your dic is dim and you've checked the dimmer switch. Does the dic show everything that it did before? Like mpg average, instant, average speed, gallons used? If it does show them, do they change? How about the trip miles, does it change?
    KOT
    Sent from AutoGuide.com Free App
    pinspade's Avatar
    Aug 2012
    perris, ca
    189
    Quote Originally Posted by Kingoftypos View Post
    KOT
    Yes everything works as before, calculates everything just fine. I've checked to verify to.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    i doubt they blew out the smleds but it's quite possible that they blew out or didn't connect power to the circuit that feeds them
    pinspade's Avatar
    Aug 2012
    perris, ca
    189
    But if they didn't connect power wouldn't the whole screen ow power on?
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    35
    717
    Id check the connectors on the back of the dic make sure they are put back on correctly, its also possible when they have done the modifications they have maybe cut through the pcb board and forgot to reconnect a track?
    Sep 2007
    Wilmington, NC
    13,986
    well there's probably main power then there's probably lighting power ... you'd have to reverse engineer the circuit board as i'm sure there's not schematic in the service manual since these types of parts are usually black boxes in that regard
    pinspade's Avatar
    Aug 2012
    perris, ca
    189
    Whenever I get some time I'll take it all a part and investigate and see if I can see what's wrong. Hopefully a easy fix.
  15. Remove Advertisements
