ly7 facts?
Results 1 to 6 of 6
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, ly7 facts? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; A friend of mine came across the data. I thought these motors ran off of regular fuel?. Engine specifications: 2004 ...
    ztollon's Avatar
    ztollon is offline Cadillac Owners Enthusiast
    Aug 2012
    629
    ly7 facts?
    Engine specifications: 2004 3.6L Global V-6 Engine (LY7)
    Configuration 3.6L 60-degree DOHC V-6
    Peak Power (SAE net) Estimated 255 hp @ 6,500 rpm
    Peak Torque 250 lb.-ft./339 Nm @ 2,800 rpm;
    (90% of peak produced from 1,600 rpm to 5,800 rpm)
    Displacement (cc) 3,564
    Bore x Stroke 94 mm x 85.6 mm
    Valvetrain Dual overhead camshaft
    4-valve-per-cylinder
    Roller-finger followers valvetrain
    Hydraulic lash adjusters
    Four-cam continuously variable cam phasing
    Two-stage roller-chain camshaft drive
    Variable Cam Timing Intake: 132 degrees ATDC initial timing
    50 crankshaft degrees advance authority
    Exhaust 111 degrees BTDC initial timing
    50 crankshaft degrees retard authority
    Compression Ratio 10.2:1
    Bore Centers 103 mm
    Firing Order 1-2-3-4-5-6
    Fuel Shutoff 6,700 rpm
    Engine Idle Speed 600 rpm
    Fuel System Sequential port fuel injection (returnless)
    Engine Management Torque-based; Bosch Motronic ME 9 32-bit micro-hybrid controller
    Intake Manifold Dual-plenum, equal-length with 2-position variable volume control (resonance tuned)
    Throttle 68-mm single bore; electronic control (ETC)
    Ignition Individual coil-on-plug; individual cylinder knock control
    Fuel Requirement Premium fuel recommended
    Emissions Controls Dual close-coupled catalytic converters
    (1.15L ultra-thinwall ceramic)
    Positive crankcase ventilation (PCV)
    Intake- and exhaust-cam phasers (EGR)
    Evaporative emissions system
    aviatordave is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS, 1976 Seville (sold)
    Apr 2013
    San Antonio
    68
    143
    Re: ly7 facts?
    the owner's manual for my '07 3.6 states:
    "If your vehicle has the 3.6L V6 engine (VIN code 7), use regular unleaded gasoline with a posted octane rating of 87 or higher. For best performance or trailer towing, you may choose to use middle grade 89 octane."
    mine runs great on 87
    DavidBoren's Avatar
    DavidBoren is offline Cadillac Owners Enthusiast
    Automobile(s): Volant, VMAX, RX catch can, tranny cooler... RIP
    Jul 2012
    Portland, OR
    31
    518
    Re: ly7 facts?
    My LY7 runs great on premium fuel. E93, eat it up. Mmm-mm, Techron.
    Tlorenzen is offline Cadillac Owners Connoisseur
    Automobile(s): 03 CTS (Dead), 06 3.6 CTS(Sold), 07 CTS-V
    Jan 2011
    Melbourne, FL
    1,504
    Re: ly7 facts?
    Quote Originally Posted by DavidBoren View Post
    E93 is 93% ethanol...did you get new injectors?? or do you mean 93 Octante lol.
    DavidBoren's Avatar
    Jul 2012
    Portland, OR
    31
    518
    Re: ly7 facts?
    Second time I made that mistake, dammit. Yes, 93 octane. I might be stupid.
    Jan 2011
    Melbourne, FL
    1,504
    Re: ly7 facts?
    That's alright..I misspelled Octane haha.
  9. Remove Advertisements
