drivers side oil leak 2003 cts
Results 1 to 11 of 11
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, drivers side oil leak 2003 cts in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; i am trying to find a oil leak in my 2003 3.6 cts sport. i have seen people say valve ...
    zaxcar1 is offline Cadillac Owners Member
    Automobile(s): cts
    May 2013
    11
    i am trying to find a oil leak in my 2003 3.6 cts sport. i have seen people say valve cover gaskets, but i am not sure. it seems to be coming out by the motor mount drivers side. i was thinking maybe the oil filter housing, but not sure. any help thanks?
    arogers260's Avatar
    arogers260 is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Luxury/Sport package
    Mar 2012
    Indiana
    722
    Quote Originally Posted by zaxcar1 View Post
    Are you sure its an 03 if you have the 3.6? But most likely it is your valve cover gaskets if you don't have the pcv upgrade. I'm not sure if the pcv update applies to the 3.6 but if your car is an 03 it would apply to the 3.2.
    Automobile(s): cts
    May 2013
    11
    Re: drivers side oil leak 2003 cts
    your right its a 2004, its my wifes car. my truck is a 03 i have too many cars to deal with. lol
    and whats the pvc upgrade?
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    I'm not sure if it applies to the 3.6, I think it was for the 3.2 motors only.
    69 Camaro's Avatar
    69 Camaro is offline Cadillac Owners Member
    Automobile(s): '04 SRX 3.6 AWD, 69 Camaro, 98 Yukon
    Apr 2012
    Cheyenne, Wyoming
    94
    I have a leak in the same general area. It appears to be coming from part of the oil filter housing. I'm using/leaking about a quart every 700 to 800 miles. I'm sure that it's using some as this engine is known for some oil consumption. I'll try to post a pict that I found on another post on this site. I haven't talked to anyone about it due to high cost of cadillac service at dealerships. I have to park it over a sheet of cardboard in the garage because it leaves a couple of silver dollar size spots every time I park it. Anyone else experienced a leak from this area and were you able to fix it? See attached link for picture..
    http://s709.photobucket.com/user/dga...ml?sort=3&o=39
    Automobile(s): cts
    May 2013
    11
    that makes sense. it looks like its coming from that genral area of the engine. and it looks like the oil pump
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    Does the 3.6 have an oil filter adapter seal? I know mine does maybe that could be your leak.
    Automobile(s): cts
    May 2013
    11
    Automobile(s): cts
    May 2013
    11
    ok so took the filter housing off and sure enuf all the bolts were loose. so i removed it and replaced with a GM gasket cleaned off the car and no leaks, so far ol. thanks for all the help
    champ52475 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2008
    1
    I Had a leak mine was coming from the oil Pressure switch they cost about $12.00 and easy can be replaced check out that for your issue
    CadillacCTS04Pearl is offline Cadillac Owners Member
    Automobile(s): 04 CTS
    Feb 2017
    44
    1
    Hello buddy,
    I have the same problem, how hard was it to change the gasket because I don't know where to start. I've had her for 2 year's I'm use to working on Honda's/Acura's so this is new to me. Can you call or text me 7579309034(Will) it's driving me crazy.
    Hello buddy,
  14. Remove Advertisements
