Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: Help please. 2007 cadillac cts shaking
    Jun 2013
    8
    Hi guys, I'm new to this forum. My name is Jennifer and I'm having a problem with my car.
    I inherited a 2007 Cadillac CTS V6 from my father a few months ago so I don't know too much about this car. I had the tires changed, and put in new rotors and new brakes last week.
    Today my boyfriend started the car to go to work and he called me and let me know it was shaking, which it never does. I went outside and the temp gauge was already in the middle (after only about 3 minutes of the car turning on) ... Then the check engine light came on. The car has no leaks and the info system only says to check window washer fluid which clearly isn't the problem. The car never overheated but continued to shake. Can anybody help me out??? Thank you!
    djkdawg's Avatar
    djkdawg is offline Cadillac Owners Fanatic
    Automobile(s): 2005 cts 3.6L
    Jun 2011
    Irving, TX
    31
    107
    Does it shake at idle or does it shake as your slowing down ?
    Blayne's Avatar
    Blayne is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS sport model/package
    Sep 2012
    Sudbury, Ontario Canada
    1,058
    Hey Jennifer welcome to the forum. First, the heat gauge in the middle is normal operating temp. So no worries there. The washer fluid being low will give the prompt to fill it. Since you say that you just got the brakes and tires done, I would bring it back to them. Most places use stick on weights which are super well known to fall off. So you may have a tire out of balance. Also, if they are new tires it isn't unheard of for the tire to have a broken steel belt in it which would also make it shake.
    Did the car shake at all before you brought it in for the tires and brakes? We're they done at the same time by the same shop? Do you feel the shake in the steering wheel or on the floor with your feet? Does the shaking seem to happen at one or two specific speeds?
  5. #4
    Jun 2013
    8
    Hey guys, thank you so much for responding! The shaking feels like it's everywhere. The floor, seats, steering wheel and I didn't want to move the car so I'm not sure if it shakes while moving, def in idle though. Also, the tires were done at the same shop as everything else and the car never shook before that.
    Ohh and also, I had my brother in law check it out and he said that one of the radiator hoses felt like it had very little pressure in it.
  6. #5
    djkdawg's Avatar
    Jun 2011
    Irving, TX
    31
    107
    Check all vacuum lines to make sure they are connected, since you just had tires put on I was hoping the shop forgot to balance them but if its shaking in idle, I could be alot of things, vacuum lines, emissions, bad motor mounts, I would try seafoaming it if it ran fine a few days before it started shaking, also could you record us a video that might help alot more
  7. #6
    Blayne's Avatar
    Sep 2012
    1,058
    Haha wow ok, I thought it was a shake while driving. Sorry a out that I read it all wrong. One of the hoses will feel like it has less pressure. That will happen until the thermostat fully opens and allows coolant back through the rad. When you start your car the coolant recirculates through the engine to heat it up. Once hot then it goes to the rad. Did they do ANY other work at the shop? Did you get any maintenance done on the engine?
    Also, next time you are in your car, hold down the F1 and F6 buttons and it will bring up the diagnostic codes. Let us know if there are any codes on there.
  8. #7
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,061
    Quote Originally Posted by Blayne
    That won't work in a 2007, only 2003.
  9. #8
    Blayne's Avatar
    Sep 2012
    1,058
    Quote Originally Posted by curtc
    Ahhh crap that's right. Thanks for the correction Curt!!
  10. #9
    Mar 2010
    Detroit, USA
    12,711
    Re: Help please. 2007 cadillac cts shaking
    Quote Originally Posted by jmarie__ View Post
    Hello Jennifer,
    Welcome to the forum. I see other members have already engaged with you about your issue with your CTS shaking. If you are thinking about taking it into a dealership, let me know and I can continue to act as a liaison. If you have other questions or concerns, I am here to assist. I can be reached via private message or at socialmedia@gm.com "ATTN LAURA".
    Regards,
    Laura M.
    Cadillac Customer Service
  11. #10
    Argent1's Avatar
    Argent1 is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,937
    If the CEL is on, get the codes & post them. Could be a bad coil or plug, or any number of ignition or even intake probs.
  12. #11
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,061
    Yep, take it over to Autozone or any other large chain parts store and have them scan the codes. They should be able to tell you what the code(s) mean too, post those back here and we can help you figure this out
  13. #12
    DavidBoren's Avatar
    DavidBoren is offline Cadillac Owners Enthusiast
    Automobile(s): Volant, VMAX, RX catch can, tranny cooler... RIP
    Jul 2012
    Portland, OR
    31
    518
    Hello and welcome, Jennifer.
    You said the car did not overheat, but continued to shake...
    So it stays on without sputtering and dying?
    What does it sound like from outside the car?
    Does it backfire?
    Does it have oil?
    Not that this sounds like a low oil situation, its just best to keep on top of the engine oil in these cars. And if you are already looking under the hood, might as well check, and fill as necessary.
  14. #13
    Jun 2013
    8
    Thank you all so much for helping me out! I decided to bring it to the shop that did all the previous work. They said it misfired so the changed spark plug #4 and the coil. Do you all think that I should change the rest of the spark plugs on my own or is it not likely that the other ones will misfire?
    I hope I don't sound annoying with my questions ... I had a Honda civic for 4 years before getting this car and was JUST beginning to learn about that car lol. This car is sooo much better than the civic and I feel like it's more complicated too lol
  15. #14
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,281
    You turn wrenches???
    KOT
  16. #15
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,061
    How many miles on the car? If you're under 100k I wouldn't worry with changing spark plugs just yet.
  • You may not post replies
