Radio, Onstar and chimes are not working
Results 1 to 7 of 7
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Radio, Onstar and chimes are not working in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I own an 2007 CTS. The problem that I am having is the radio will come on without sound. It ...
    Darrell B is offline Cadillac Owners Member
    Automobile(s): 2007 CTS
    Jun 2013
    59
    I own an 2007 CTS. The problem that I am having is the radio will come on without sound. It looks normal like it is working but with no sound. There are no chimes when the key is put in. The onstar looks to be working but no sound. I have pulled the plugs on the amp in the trunk and then reinstalled. I tested the amp fuse and the radio fuse under the rear seat and they are ok. It seems anything associated with the speakers in the car does not work. Does anyone have any suggestions ?
    Thanks, Darrell
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    35
    717
    Re: Radio, Onstar and chimes are not working
    Most of the speakers are tied into the bose amplifier, my guess would be that its possibly the amp gone bad, worth checking the power inputs and testing that it is grounding to the chassis correctly with a Digital multimeter.
    mattpattabhi is offline Cadillac Owners Member
    Automobile(s): Cadillac cts 2003
    Apr 2013
    22
    4
    i have the same problem. Checked ground and it seems ok. Bought a new amp,radio, and replaced fuses and it still no sound... The volume bar and steering wheel volume buttons don't seem to be doing anything... Please help.
    Jun 2013
    59
    I will check the ground. Hopefully thats the problem. Thanks
    DavidW87 is offline Cadillac Owners Member
    Automobile(s): 2004 CTS 3.6 V6, AFE CAI, CTS-V grill,
    Oct 2011
    44
    I had this problem when I first bought my CTS from auction. Literally all the same symptoms, no sound, no chime, no change with DIC interactions. It turned out to be the bose amplifier. While I realize matt said he tried that and it didn't work, I would double check the connections to the amp as they can be difficult. Also beware where you buy the amp from I bought one on ebay and I was sent a broken one thankfully paypal had my back and all was resolved. I think I picked mine up in the end for around $150, compared to the $800 or $500 (I can't remember) that the stealer-ship wanted.
    Apr 2013
    22
    4
    Well i have one last question, the stock bose amplifier is the only compatible amp for cts 2003? thanks,
    Quote Originally Posted by DavidW87 View Post
    Oct 2011
    44
    I've sent you a private message with some links that should help you, cross reference those numbers on the amps against the one in your trunk. Let me know if you need help accessing the amp itself.
  10. Remove Advertisements
