my horn doesn't work properly.?
Results 1 to 10 of 10
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, my horn doesn't work properly.? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; So my horn wad going out. I mean it would be strong sounding then get weak. This listed about a ...
    pinspade's Avatar
    pinspade is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac CTS 3.6 liter
    Aug 2012
    perris, ca
    189
    So my horn wad going out. I mean it would be strong sounding then get weak. This listed about a week. Now nothing at all, no sound. Every now and then I can get it to honk but it will only honk the one time then nothing for weeks. Any idea? I don't think it's completely broken since it works sometimes
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,221
    Check the horn bracket. It's using it for ground. Make sure the mating surfaces are clean and what not.
    KOT
    pinspade's Avatar
    Aug 2012
    perris, ca
    189
    Quote Originally Posted by Kingoftypos View Post
    KOT
    I didn't know that, thanks. I'll check that and let you know.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,687
    Re: my horn doesn't work properly.?
    Quote Originally Posted by pinspade View Post
    Hello pinspade,
    If you check the horn bracket like Kingoftypos said and that doesn’t work, and would like to take your CTS into the dealership for a diagnosis. I would be more than happy to assist you in working with the dealership. Please private message us if that is the route you would like to take. Keep us updated on this situation.
    Gregory W.
    Cadillac Customer Care
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,313
    My horn died recently, too. I'm pretty sure the horn relay has gone bad, and your thread just reminded me I need to get that fixed.
    Does your horn work when you lock/unlock the doors? (I normally have that feature turned off, but I turned it back on so that I could test to be sure it wasn't the horn button in the steering wheel that was bad.)
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    AAIIIC's Avatar
    Aug 2007
    6,313
    OK, mine is not the relay. Pretty easy to test the relay - pop the hood and remove the cover from the fuse/relay box. Open the driver side window. While standing alongside the car, reach in the window and press the horn button on the steering wheel. If the relay is working, you'll be able to hear it click each time you press the steering wheel. If you don't hear it click (or even if you do, and just want to test another relay) there are multiple, identical relays in the panel, so you can just trade with another one to see if the horn is still dead.
    I unplugged the harness from the horn, re-seated it, and it works now. That's happened a couple/few times recently, so I'm not sure what the deal is. Didn't have time to fiddle with it more last night.
    Teedoe's Avatar
    Teedoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Base and 2014 Cadillac CTS VSport Premium
    Dec 2009
    Central Florida
    525
    Quote Originally Posted by AAIIIC
    Do you have a pic of where the horn and harness is located? My horn just went out but the relay still clicks. Maybe I need to check the harness.
    AAIIIC's Avatar
    Aug 2007
    6,313
    Look through the grille on the passenger side, you'll see the horns. They're bolted to the back of the bumper beam.
    Apr 2009
    Ledyard, CT
    38
    9,221
    Quote Originally Posted by AAIIIC View Post
    Passenger side??? I don't know how your's ended up over there. But mine are on the driver's side. Just under the air filter housing.
    KOT
    AAIIIC's Avatar
    Aug 2007
    6,313
    I know how they ended up there - GM installed them there. Must be a V vs. V6 difference. I thought about throwing the "it may be different on your car since I have a V" caveat in there when I posted, but I didn't figure there was any reason the horns would be mounted in different locations on the two versions of the car.
    You can see mine here on the left side of the picture poking up from behind the bumper beam.
  13. Remove Advertisements
