eibach spring help
Results 1 to 2 of 2
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, eibach spring help in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I was looking into purchasing eibach spring kit and came across this "Comments: Vehicles equipped with self-leveling rear dampers must ...
    acom is offline Cadillac Owners Member
    Automobile(s): 07 cts 2.8
    Jun 2013
    28
    eibach spring help
    I was looking into purchasing eibach spring kit and came across this "Comments: Vehicles equipped with self-leveling rear dampers must replace with non self-leveling dampers such as FE1 or FE2 dampers to properly lower." how do I determine if theyre self leveling... I have a base model cts 2.8.
    Blayne's Avatar
    Blayne is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS sport model/package
    Sep 2012
    Sudbury, Ontario Canada
    1,058
    Then you likely don't have it. The self leveling "Nivomats" are in the performance suspension. I know it was on my FE5's and they are probably on the V FE4's also. If you look under your spare tire cover you will have a tag with all your build codes. Look at it and you will probably see the FE1 or FE2 code on there. So you should be good to go on the springs with the stock shocks.
