3.2l engine damage
Results 1 to 5 of 5
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 3.2l engine damage in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; My timing belt skiped a tooth and caused some damage to the engine. I was curious, being that the 3.2 ...
    slydwys is offline Cadillac Owners Member
    Automobile(s): cts
    Jun 2013
    34
    3.2l engine damage
    My timing belt skiped a tooth and caused some damage to the engine. I was curious, being that the 3.2 is hard to find for a replacement, can a 3.6 be swapped in with relative ease? Otherwise I was thinking of an LS swap, if I can find the correct subframe as I believe theyre different. Thanks for the help.
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    Re: 3.2l engine damage
    a 3.6 or even a LS can be put in for the right amount of money, but you can still get a 3.2 and for much cheaper than what it would cost to go to a 3.6 or even a LS engine
    Automobile(s): cts
    Jun 2013
    34
    Thanks. I've recently found reman heads for a good price. That might be my go to for best and easiest results.
    txbest1980's Avatar
    Dec 2008
    36
    6,414
    make sure that you get the heads redone on both sides...or if you only had one side get damaged, go ahead and replace the other side also...it will be worth it in the long run
    Teedoe's Avatar
    Teedoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Base and 2014 Cadillac CTS VSport Premium
    Dec 2009
    Central Florida
    525
    Say it ain't so!! The rise of Txbest! How u been bro?
  8. Remove Advertisements
