Rubbing noise when slowly turning
Results 1 to 6 of 6
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Rubbing noise when slowly turning in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; When slowly turning i hear and feel a noise that feels like something is rubbing. When i took the front ...
    foland is offline Cadillac Owners Member
    Apr 2013
    26
    When slowly turning i hear and feel a noise that feels like something is rubbing. When i took the front wheels off it looked like there were little scratch marks where the wheel might have rubbed it (I have the 18inch wheel package and the correct tires on the wheels) There is VERY little play between the struts and the wheel(maybe the width of a penny?). I dont know if this is normal or not. I took it to a shop and they couldnt find anything wrong(i suspected bearings but it wasnt) The only other suggestion they had was to get an alignment.
    Have any of you had this issue?
    Kad4Life is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6 FE5 Blk/Blk 'Nadine'
    Jun 2010
    Northeast
    70
    1,063
    Re: Rubbing noise when slowly turning
    Bad Diff. ?
    That's what mine was .
    Rubbing noise on slow, tight turns .
    Apr 2013
    26
    Quote Originally Posted by Kad4Life View Post
    Bad Diff. ?
    man, that sounds the same as mine. How much was the fix? Is there anyway for me to check and see if that is the problem myself?(i dont know anything about cars)
    djkdawg's Avatar
    djkdawg is offline Cadillac Owners Fanatic
    Automobile(s): 2005 cts 3.6L
    Jun 2011
    Irving, TX
    31
    107
    Also check the sway bar bushings to see if they are bad
    Iceman_jd's Avatar
    Iceman_jd is offline Cadillac Owners Fanatic
    Automobile(s): 2007 3.6 CTS
    Oct 2012
    Arizona
    112
    If it's a limited slip differential you should change the differential oil and limited slip additive. Sounds like the symptom of sticking clutch plates.
    Jun 2010
    Northeast
    70
    1,063
    Mine was replaced under warranty .
  9. Remove Advertisements
