Nasty Whining Noise
Results 1 to 8 of 8
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Nasty Whining Noise in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Help guys. I need to solve this loud whining noise on my 04 CTS 3.6L. The whine noise increases. with ...
    956Caddy's Avatar
    956Caddy is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac Cts Black Raven
    Apr 2012
    Harlingen,Tx
    289
    Nasty Whining Noise
    Help guys. I need to solve this loud whining noise on my 04 CTS 3.6L. The whine noise increases. with Rpm's and decreases . Also it sounds like a bad bearing but also heard of timing chains wear out, which I hope this isn't the case. Thanks for falls input.
    here's the YouTube URL.
    https://www.youtube.com/watch?v=QBLj...e_gdata_player
    Blayne's Avatar
    Blayne is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS sport model/package
    Sep 2012
    Sudbury, Ontario Canada
    1,058
    I'm not an expert on the tiki g chain sound, but that seems like it might be a bad pulley wheel. Like maybe the tensioner or something. For starters, get a can of WD-40 of something and get in there and spray the back (bearings) of all the pulleys. If the noise lessens or goes away for a short time.....bingo. If it is still there then it may be the timing chain!
    956Caddy's Avatar
    Apr 2012
    Harlingen,Tx
    289
    I thought of that because I sounds like the rubber on a bearing is out and is metal to metal contact but wasn't sure.
    Iceman_jd's Avatar
    Iceman_jd is offline Cadillac Owners Fanatic
    Automobile(s): 2007 3.6 CTS
    Oct 2012
    Arizona
    112
    Re: Nasty Whining Noise
    Yeah, I start by taking the air intake out of the way then remove the belts so you can get a good look. Use your hands to move/ spin everything you can get your hands on. Look for brown, reddish or black dust that's a good clue too.
    956Caddy's Avatar
    Apr 2012
    Harlingen,Tx
    289
    Confirmed, I sprayed the rear of all the bearings and bam the noise went away for a while but soon came back. Only problem is that i didnt do one at a time but at least i now know its just a bearing problem but to me sounds like the harmonic balancer. It's not loose just noisy.
    956Caddy's Avatar
    Apr 2012
    Harlingen,Tx
    289
    Okay so today I removed belts, spun all bearings and no noise but removed lower idler pulley and noticed two metal plates one in front and behind pulley removed them both and ding noise gone and sounds normal. My suggestions was those two plates/spacers were rubbing against pulley and at high rpm the noise got louder etc.
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    35
    717
    sounds like you might need a new one then, must be that the bearing in it's warn causing movement up and down, worth trying to wiggle it up and down by hand to confirm.
    Stu
    956Caddy's Avatar
    Apr 2012
    Harlingen,Tx
    289
    Well i removed those two plates and put the same pulley back on and the noise is not there anymore. has been running noiseless for about 3 days now.
  11. Remove Advertisements
