CTS to CTS V front bumper conversion - Page 4
Page 4 of 4 FirstFirst 1234
Results 46 to 55 of 55
Like Tree8Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, CTS to CTS V front bumper conversion in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; 12335777Front Bumper Cover, CTS-V (must be painted) 25750634Right Bumper Extension (new inner fender well cover) 25750635Left Bumper Extension 25753700Right Fog ...
  1. #46
    CtsLAC's Avatar
    CtsLAC is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS 3.6L
    May 2013
    Houston, Texas
    24
    113
    Re: CTS to CTS V front bumper conversion
    25753700Right Fog Lamp (includes air vent for brakes)
    25753699Left Fog Lamp
    25752695Lower Air Deflector (the lower engine cover/deflector)
    25750638Lower Stainless Mess Grille
    15147586Upper Stainless Mess Grille (includes emblems)
    This is what it shows on cadillacfaq now I know the mesh grills are optional but is inner fender wells ubare talking about be the same as the right and left bumper extensions that they are talking about?
    Ok have gathered some pretty good info on what I need to do the bumper swap! Just need to know if I need to get a specific year v bumper or if any v bumper will work. I have found one for sale for $250 in good condition. Guy says only thing wrong with it is that some of the grill tabs are broken. I can probably get it for $200. He says its for an 08-12 will this one work?
    DavidBoren and DavidBoren like this.
  2. #47
    JhughesCTS's Avatar
    JhughesCTS is offline Cadillac Owners Fanatic
    Automobile(s): 2003 cts
    May 2012
    portland, OR
    29
    188
    If you have 1st gen you need a 1g bumper cover. 08-12 is 2nd gen.
  3. #48
    J W
    J W is offline Cadillac Owners Enthusiast
    Automobile(s): CTS /CTS-V / Escalade EXT / Coupe
    Jun 2009
    605
    I would not get one with broken tabs. You will regret it later when something does not fit as snug as it should.You will need to change the front half of the wheel liner if you want a proper fit. The V liner is a different shape in some areas.
    V liner on the left.
    Removing the bumper is fairly easy. It's mainly a bunch of push pins along the top and some underneath where it attaches to the air deflector pan and wheel liners. Once you have all the pins out there are 3 10mm bolts on each inner side right above your side markers. Loosen the two that are further back. Remove the one in the front completely. Do this on both sides. Removing the side marker lights will help make it easier to get to also. They just pop out by pressing on the tab at the top of the light from inside and pushing out.
    The top of two bolts that you loosened on both sides fit into a key hole slot. If you slightly pull each side towards the front of the car it should drop down.
    If you are going to change the upper grille now would be a good time to do it. The push pins will be easier to get to. Also putting the lower grille and fogs too.
    Once all that is done just reverse the process.
    If you do put the air ducts in, attach them to the fog light brackets before you put on the wheel liners. On the bottom side of the ducts and where they attach to the fog bracket there is a hole for a push pin.
    You may need to get another rubber air dam deflector. I'm not sure but for some reason i believe they are different lengths. And also the pan is different. Hope this helps.
  5. #49
    CtsLAC's Avatar
    May 2013
    Houston, Texas
    24
    113
    Thanks for the info and pics man its helpful and easy to follow! Yea well onlyb the tabs for the grill are broken but either way it's for a second gen cts. The guy that was selling that bumper has a second one that's already primed. Is gonna tell me what year cts it will fit today. Have my fingers crossed
  6. #50
    J W
    Jun 2009
    605
  7. #51
    dcab1017 is offline Cadillac Owners Member
    Nov 2013
    26
    3
    SmileQUICK QUESTION. cts-v front bumPer on cts?
    I was wondering if it was possible to install a cts-v front bumper on my 03 cts. If so, what year cts-v will fit?
  8. #52
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,454
    Re: QUICK QUESTION. cts-v front bumPer on cts?
    Search for "front bumper" and guess what you'll find? http://www.cadillacforums.com/forums...nt-bumper.html
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  9. #53
    Blayne's Avatar
    Blayne is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS sport model/package
    Sep 2012
    Sudbury, Ontario Canada
    1,058
    Yes you can.....and any 03-07 CTS-V
  10. #54
    AAIIIC's Avatar
    Aug 2007
    6,454
    Merged 4 or 5 threads about CTS-V bumper conversions on the CTS. I'm sure there are other threads, too, but this one now has good pictures and parts lists.
    J W likes this.
  11. #55
    AlpineCTS is offline Cadillac Owners Member
    Apr 2013
    78
    There is no reason to swap wheel wells in this bumper conversion the 3.6 wheel wells 5/6 mounts line up an you just need to poke a hole for the very front hole of the liner an i spent 6 dollars on new plastic push tabs that were a bit bigger from lowes.
  12. Remove Advertisements
