battery or alternator?? please help
Results 1 to 12 of 12
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, battery or alternator?? please help in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; yesterday while driving i got a warning on the info center, well two, service electric system and charging system, me ...
    knals's Avatar
    knals is offline Cadillac Owners Member
    Automobile(s): Cadillac Cts 03 V6 3.2L
    Dec 2012
    24
    44
    yesterday while driving i got a warning on the info center, well two, service electric system and charging system, me not thinking about what could happen, just turned off the car, see if it would reset, but then the car didnt start anymore, finny got a batterie charger n connected it, after a while i could start it again but once taking of the carger the car slowly dies, and does not start without charger, also in the information center the batterie volts do not go upper the 12.9 volts, please help, really need to move the car from there. any help is appreciated.
    Blayne's Avatar
    Blayne is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS sport model/package
    Sep 2012
    Sudbury, Ontario Canada
    1,058
    Put the charger back on and get it started. Get a volt meter and measure the voltage at the battery with the car running. If you aren't getting at least 12 volts.....(should be almost 14) then the alternator is bad. If you get good voltage at the battery with it running then its the battery.
    knals's Avatar
    Dec 2012
    24
    44
    Re: batterie or alternator?? please help
    even if the charger is till on the batterie? because once i disconect it the car dies
    J W
    J W is online now Cadillac Owners Enthusiast
    Automobile(s): CTS /CTS-V / Escalade EXT / Coupe
    Jun 2009
    605
    Sounds like your alternator. A good alternator should keep the car running when the battery is disconnected. But im not a mechanic so maybe someone else will chime in.
    knals's Avatar
    Dec 2012
    24
    44
    took it to the shop just now, drove a while n then the car shut down again, happend about 4 times b4 i got to the shop, mechanic said it would b ready by the end of the week so ill wait ill friday to update results, thanks guys
    Blayne's Avatar
    Sep 2012
    1,058
    End of the week? That's a long time to change an alternator which I am 99% sure it is!!!
    knals's Avatar
    Dec 2012
    24
    44
    Well the guy had about 11 cars due still soo i guess ill jst have to wait my turn, only mechanic around here that does that kind of work
    TomV is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac CTS 2003
    Aug 2006
    Annapolis, MD
    144
    Quote Originally Posted by J W View Post
    I will chime in!
    Never power the car without the battery. You will fry the alternator.
    A fully charged battery will start and run the car without a problem despite the alternator. If the car dies when the charge is removed then your battery is no good.
    The mechanic can/will test your battery with his external load box and tell quickly if the battery is good.
    With a good battery in the car, the alternator can be tested. If it is not delivering at least 14 volts (as Blayne suggests) then the alternator (or associated wiring) is the culprit. Another culprit is a loose belt, though that may not be as much of an issue with the serpentines as it was back in the day with cars used individual belts.
    I do not know where you live, but any mechanic with a shop sign should be able to properly diagnose this type of problem.
    J W
    Jun 2009
    605
    Re: battery or alternator?? please help
    The reason for going with the alternator theory is because the OP stated his car would not start so he gave the battery a charge. After getting the charge the car started but slowly drained and died again. Hence the fact that either the battery is no good (but it did take a charge). Or the batter is not getting charged by the alternator. That is why I suggested the alternator might be bad. Of course as I said i'm no mechanic. I learn that alternator test from a mechanic. Or maybe the wire from the batter to the alternator has come disconnected.
    Aug 2006
    Annapolis, MD
    144
    Knals,
    When your car died on the way to the shop, did you have your lights on during the drive? How far did you drive to get to the shop? How did you get the car restarted, did you jump start it with another car?
    knals's Avatar
    Dec 2012
    24
    44
    i was able to drive about 5 miles, i dont trust jump starting anymore, i used a battery charger, got the car back yesterday, it was the alternator, the guy fixed it for 80 dlls, and gave me 2 year guarantee, car works perfect again, thank you for all the help
    J W
    Jun 2009
    605
    Glad to hear your and running again.
  15. Remove Advertisements
