Results 1 to 12 of 12
Thread: Speedometer Reading 25 MPH Over The Actual Speed!
    Awesome1 is offline Cadillac Owners Fanatic
    Automobile(s): CTS
    Jan 2009
    69
    127
    My 2003 Cadillac CTS 3.2 V-6 Speedometer is reading approximately 25 MPH over the actual speed. What would cause this to happen? If it is the speed sensor on the trans, what happens if it is removed, will the oil come pouring out? Since there is no
    dip stick tube, how would I top off the oil level with what ever oil spilled out? Thank you for your support.
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,281
    Are you in metric or standard reading? What does your HVAC read in, F or C?
    KOT
    Automobile(s): CTS
    Jan 2009
    69
    127
    Re: Speedometer Reading 25 MPH Over The Actual Speed!
    I'm willing to bet I'm probably in the metric reading mode because we notice that the HVAC reading has strange new numbers as well. So, how do I switch it back to the standard reading? I recall this happening once before when we first purchased the car years ago. I don't recall how we switched it back to the standard readings. Thank you for your support.
  5. #4
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,061
    Flip through the DIC options, you'll find it...
  6. #5
    Automobile(s): CTS
    Jan 2009
    69
    127
    Ok, I pressed the button on the right side of the radio display until I got to the English reading. Once I chose that, I noticed that the HVAC reading went back to normal. So, it had to be in the Metric mode. Thanks for your support and have a nice day.
  7. #6
    Argent1's Avatar
    Argent1 is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,937
    In Metric the speedo will say KPH, in English, it will say MPH.
  8. #7
    Apr 2009
    Ledyard, CT
    38
    9,281
    Quote Originally Posted by Argent1 View Post
    Hmm, there must be something wrong with the speaker in my car. Because I don't hear anything say "KPH" or "MPH".
    KOT
  9. #8
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,463
    Check your DIC settings, KOT, you must have turned off the talking speedometer at some point.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  10. #9
    Argent1's Avatar
    Nov 2010
    2,937
    Quote Originally Posted by Kingoftypos View Post
    KOT
    That's wierd..............that little motor you got shouldn't make enough noise to drown it out...........could also have something to do with the Nut that holds the steering wheel, I've heard that is the cause of many probs. .
  11. #10
    CadillacAsAlways's Avatar
    CadillacAsAlways is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS 3.2L, Luxury Sport, Diamond White
    Aug 2012
    Pittsburgh, PA
    659
    KOT
    I'd really suggest taking it into the dealer, sir. This is a very serious problem that should only be worked on by Official GM Technicians®
  12. #11
    Mar 2014
    1
    my 2003 CTS 3.2L V6 is having speedometer trouble. all other gauges are fine. I have already changed the speed sensor on transmission and that wasn't it. what else could it be? Does the cluster need to be replaced? Or is there something else i should look at?
  13. #12
    CTSM is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 08' 3.6 DI Performance | 07' Lux 3.6 Volant-Borla-Vsways
    Mar 2012
    943
    KOT
    Hello KOT,
    I would like to appologize about the mute / non-talking speedometer you are experiencing in your CTS. If you would please private message me your name and VIN we can set up an appointment with your local Cadillac dealer so that we can address your concerns with the speedometer and also have that nut that holds the steering wheel examined.
    Angela XXL
    Cadillac Customer Surfer Agent :*
  • You may not post replies
