service theft system and traction control light on and key stuck in ignition. - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, service theft system and traction control light on and key stuck in ignition. in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Originally Posted by djkdawg Sounds like ecm to me , do you have aftermarket amp and sub's hooked up? No ...
  1. #16
    BOXCALADE's Avatar
    BOXCALADE is offline Cadillac Owners Member
    Automobile(s): 2003 CADILLAC CTS
    Apr 2013
    miami,fl
    11
    Quote Originally Posted by djkdawg
    No I don't also the gas gauge doesn't read and the t/c light doesn't go away
  2. #17
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    35
    717
    Re: service theft system and traction control light on and key stuck in ignition.
    http://engine-codes.com/u1000_cadillac.html
    Worth checking all grounding points on the car for starters, bad grounds can cause all kinds of gremlins in these cars.
    as for the brakes, what happens when you bleed them off a little, do they free up?
  3. #18
    BOXCALADE's Avatar
    Apr 2013
    miami,fl
    11
    Quote Originally Posted by CTSUK
    I'm gonna check the grounds now thanks and for the brakes I replaced everything and flushed the whole system they work great now
  5. #19
    BOXCALADE's Avatar
    Apr 2013
    miami,fl
    11
    Update fixed the issue it was the ECM wasn't program everything is working fine expect the radio has no sound the door chime works and radio reads station and everything else just no sound anybody have an idea??
  6. #20
    brandeeknego is offline Cadillac Owners Member
    Automobile(s): 03 cts
    Jul 2013
    37
    5
    I had all the same problems and more. Changed the ECM and that did the trick.
  7. Remove Advertisements
