Radiator fitting leak? Maybe?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Radiator fitting leak? Maybe? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I was under the car doing the oil this morning and I discovered what looks to be a fluid leak. ...
    holsgo is offline Cadillac Owners Fanatic
    Automobile(s): 2007 cts
    Apr 2011
    143
    I was under the car doing the oil this morning and I discovered what looks to be a fluid leak. The hose goes from the base of the radiator, right in the middle, to the back. I jiggled things and I find the fitting in the pic to be loose. Not the nut, but the fitting into the nut. Any idea what this hose is so I can research further?
    Thanks in advance
    Apr 2011
    143
    Re: Radiator fitting leak? Maybe?
    Possibly the transmission oil cooler lines?
    Apr 2011
    143
    Well she's in the shop. It certainly is the transmission cooler lines. the fitting into the radiator has way too much play to hold fluid. I probably have 1 cup of fluid strewn under the vehicle. Glad I caught it since this would end badly if it went on for a while.
    Apr 2011
    143
    Just to give a thanks to the people on this forum. I got much info about these lines from taking a ton of time today to read all of the threads. From here on I will have the tool and I've even though about an external cooler. Friggin ridiculous. I guess I caught it early enough but what ever happened to just attaching the lines the good old fashion way, like I remember from the 80s.
    A48WillyzGuy's Avatar
    A48WillyzGuy is offline Cadillac Owners Fanatic
    Automobile(s): 2003 CTS
    Mar 2011
    Evansville, IN
    28
    294
    Glad you got it figured out. These cars are notorious for trans cooler lines, as I'm sure you've read by now.
    Obviously, were much too technologically advanced to use those primitive 80's techniques. Lol.
    rb0757 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2006
    74
    Those days of the 80's are gone engineers like to reinvent the wheel. I put the external cooler on, it helps keep the trans fluid from over heating, remember heat is one of the things that damage transmissions
    arogers260's Avatar
    arogers260 is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Luxury/Sport package
    Mar 2012
    Indiana
    722
    Quote Originally Posted by rb0757
    You happen to know the ideal tranny fluid temp for our car? I've been wondering this for awhile but haven't found a solid answer.
    Mar 2011
    Evansville, IN
    28
    294
    Generally, trans temp should be similar to engine temps. 200 F is about as high as you'd want it to be.
    Argent1's Avatar
    Argent1 is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,937
    Anybody installed a trans temp guage, or know a good spot on the tranny to install the sender ?
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    Quote Originally Posted by Argent1
    I use the torque app, it may not be 100% accurate but it's a pretty good ballpark estimate. My coolant is usually around 165*-175*. Haven't seen the tranny temp over 150*.
    Apr 2011
    143
    I passed through Pep boys this morning to see about the disconnect tools and a trans cooler. Now I need to plan this out. I did find a thread on this forum about actually removing the troublesome fitting and going direct with the hose and clamps.
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    Quote Originally Posted by arogers260
    An update on these stats after a drive today resulted in my highest value on coolant was 203* tranny temps highest value was 188*. I do have an active coolant leak I haven't had time to fix.
    Mar 2011
    Evansville, IN
    28
    294
    Man, I wish my Torque would read my trans temps. I've been bamboozled! Lol.
  16. #14
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    Quote Originally Posted by A48WillyzGuy
    I think it is gm method 1, for transmission temp. I found it works when I start the car then doesn't change until you exit the app and then start the app back up.
  17. #15
    Apr 2011
    143
    I've followed a couple threads now on the separate cooler setup. I have just 2 questions so far, 1- I believe the line in my first pic is the feed line into the rad and the line in the second pic (blurry fitting at the top) is back from the rad to the trans? 2-how did you guys plug the rad? Just cut the fitting off the hose and leave it in the rad with a plug in it? That's for the fitting in the first pic, the second line which is alum it seems can just have a dead ended hose clamped on it.
  18. Remove Advertisements
