Door Panels
Results 1 to 5 of 5
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Door Panels in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; How would I remove the door panels so that I can replace my stock speakers with my new Boston Acoustics ...
    stedb77 is offline Cadillac Owners Member
    Nov 2004
    1
    ExclamationDoor Panels
    How would I remove the door panels so that I can replace my stock speakers with my new Boston Acoustics speakers?
    crockone's Avatar
    crockone is offline Cadillac Owners Connoisseur
    Sep 2004
    nj
    39
    1,240
    Re: Door Panels
    remove the acess panels and take out the screws.. then pop the clips with a pannel popper.. easy.
    FastCTS is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS
    Jan 2004
    Indio, Ca.
    920
    Re: Door Panels
    How do I remove the Door panels
    All Doors: On the bottom edge of the plastic door handle cover are two small cutouts. Insert a flat tool into that cutout about 1/2 - 3/4 inch and push up slightly to release the inside catch on the cover from the projection that holds it. It is best to do both at once to minimize stress on the door handle. Push up and out to remove the door handle cover while holding the door handle in the open position
    Next, just behind the door pull handle, there is an oval piece that you pry out, and behind it are two screws. Remove these screws. Next, starting at the bottom, pry the door panel up and it will begin to pop and then work it around until you have the panel completely pulled away from the door. Now push up and out to get it finally off the door.
    <LI>The front speaker is affixed to a bracket and then to the door. In the non-bose, it's a 5.25" (5 1/4") speaker, in the bose is (reportedly) a 6.75" (6 3/4") speaker. But keep in mind that it is 2 ohm (so a 4ohm speaker will produce less volume), and in both applications it's equalized (crossed) to produce below 6000hz, so you will not get very good highs from the speaker.
    The rear is removed the same, however, the speaker is screwed to the door panel, not the door. It is a 4 ohm speaker and full range
    RobertCTS's Avatar
    RobertCTS is offline Cadillac Owners 10000+ Posts
    Automobile(s): Black the Darkside
    May 2004
    Central Ohio
    22,418
    Re: Door Panels
    Just curious My '04 has a really nice factory Bose system. I think the sound is terrific! But I see a lot of members change out their system, often at great expense. I wondered why that is
    crockone's Avatar
    Sep 2004
    nj
    39
    1,240
    Re: Door Panels
    Quote Originally Posted by RobertCTS
    me too.. i would not change it unless i was puttin an aftermarket amp to the the speakers.. i think most or em robert is the nonbose.. cause that system sounds like crap.. a rental i had rented had it.. terrible.!
  8. Remove Advertisements
