Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
Thread: Flex Disc
  1. #16
    caddyshack33 is offline Cadillac Owners Fanatic
    Automobile(s): '04 CTS 3.2 5-spd Manual
    Oct 2007
    165
    Hey guys, did your vibration include a steering wheel shake or was it all "on the floor" or in the seats? I think I may have more than one vibration issue going on that has made me crazy for some time. (my steering wheel shakes intermittently between 50-60 mph, but I also have other vibs in the seats/floor). Waiting on delivery of a new softer Creative Steel flex disc to try it out. i had their polyurethane disc installed but it didn't seem to change any issue long term. I'll need to check the bolt pattern, too.
  2. #17
    Bluehaze07's Avatar
    Bluehaze07 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS
    Apr 2009
    Honolulu, HI
    1,395
    So, I installed the New softer Flex Disk from Creative Steel and 98% of my vibrations are gone. I re-installed the Bolts/washers as posted by Chris and replaced my transmission mount, and diff mount bushing. Everything seems G2G now.
  3. #18
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    Re: Flex Disc
    ah ok... i was going to say you can't buy those...
    ive got a couple backups....not for sale though.
  4. #19
    Sep 2007
    Wilmington, NC
    13,969
    Quote Originally Posted by ghettomike View Post
    Of course ;-)
  5. #20
    ctsboiha's Avatar
    ctsboiha is offline Cadillac Owners Fanatic
    Automobile(s): cts
    Nov 2012
    29
    114
    How hard is it to change the tranny mount? An where would one buy one at?
  6. #21
    Bluehaze07's Avatar
    Apr 2009
    Honolulu, HI
    1,395
    Quote Originally Posted by ctsboiha
    -- i guess the original post got messed up --
    Lift the car. Place a transmission jack on the trans oil pan. Jack the trans up a little bit to support it. Be careful not to damage the shifter linkage. There are six 15mm bolts to remove and 2 T-47/T-45 (I don't remember the exact size) Hex bolt to remove. The trans mount and bracket will be removed and you can place the new mount back on with the mounting bracket. It will only fit one way. Tighten the bolts down lower the transmission and you are done.
    My exhaust was off at the time so I Don't know how much clearance you will have with it on the car.
    Check with rippyparts (site vendor) for the trans mount or check around online.
  7. #22
    MotorMounts's Avatar
    MotorMounts is offline Cadillac Owners Fanatic
    Automobile(s): 04 Black CTS-V
    May 2009
    Salem Oregon
    51
    400
    Re: Flex Disc
    Quote Originally Posted by Bluehaze07 View Post
    Super glad to hear that our disc solved 98% of your vibrations. These flex discs have been a nightmare to figure out how to build but we have it figured out now. We have been told of this same situation by others which is another reason I'm glad we got these figured out. Thanks for giving us a shot.
    Our phone number is 503-316-1811 We're here M-F, 8-5 Pacific Time.
    http://www.creative-steel.com
    maxx@creative-steel.com
  8. #23
    unwritten is offline Cadillac Owners Member
    Automobile(s): 04 CTS 3.2 5spd manual w/Sport Pkg, 07 Grand Cherokee Diesel
    Mar 2013
    36
    Re: Flex Disc
    I installed a new soft Creative Steel flex disc in place of my front flex disc which was worn out and giving me the low speed clunking symptoms. I also installed a new trans mount. I do not have any vibrations, minimal clunk sometimes.. maybe need to replace the rear disc.
  9. #24
    May 2009
    Salem Oregon
    51
    400
    Re: Flex Disc
    Quote Originally Posted by unwritten View Post
    If you haven't checked your rear diff bushing and you're getting a clunk you should have a look. They are located at about "10:30" as you look down the drive line towards the differential, right above where the drive live meets the differential. Push up and pull down as hard as you can right where the drive line and differential meet while watching the bushing, if you get any movement the bushing is bad. The toque of the engine is a lot stronger than you are, so if you can move it by hand, it's really moving while you are driving, especially in stop and go traffic.
  10. #25
    Mar 2013
    36
    Re: Flex Disc
    Quote Originally Posted by MotorMounts View Post
    I did this and there was barely any movement in the diff bushing, most movement was in the driveshaft center bearing...
  11. #26
    Sep 2007
    Wilmington, NC
    13,969
    Yeah the center support bearing is another prime failure spot.
  12. #27
    May 2009
    Salem Oregon
    51
    400
    Re: Flex Disc
    The carrier bearings do go bad, but my money is still on the diff bushing causing a clunk. It doesn't sound like it's bad enough to take it apart to find out for sure, but if it gets worse that will change. The good news is that it will be annoying to the point of repair before any irreparable damage is done. Drive it.
  13. #28
    briggy's Avatar
    briggy is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 3.6L 2005 80,000 Miles
    Dec 2009
    Southern California
    41
    958
    Re: Flex Disc
    I'm about to go down this road as I am getting the 'clunk'. It sounds like the softer creative steel guibos are the way to go. It also sounds like I need to change the front rare, and trans mount. what else am I missing.
  14. #29
    May 2009
    Salem Oregon
    51
    400
    Re: Flex Disc
    Quote Originally Posted by briggy View Post
    If you're getting a clunk I would also inspect the rear diff bushing.
    I thought I clear-up one small detail, the couplers that we sell now (and for the past several months) are very close to the stiffness of the factory units, but use urethane instead of rubber. They are softer than our previous models, but now compare to the factory. The great news is that they don't vibrate and our prototype is still going strong, which has been over a year now.
  15. #30
    mattt0305's Avatar
    mattt0305 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 6 speed manual tarnished platinum
    Feb 2011
    Southern Illinois
    333
    Re: Flex Disc
    My problem was that the bushing labeled 4 in the kf diagram rippy posted was slopped out. It fits on the pin that sticks out of the output flange of the tranny. The guibo does not hold the drive shaft on center, the pin and bushing do, so my CS front flex disc only lasted a
    couple of weeks. Every time I would step on the gas the drive shaft would want to rotate off center and trashed it. New drive shaft and problem solved. After what I spent trying to fix the old shaft including labor and a carrier bearing(that I didn't need), I could have almost paid for the new one since my buddy has a body shop and gets parts at his cost. Plus that center u-joint is not serviceable so it's all new now.
  • You may not post replies
