Results 1 to 3 of 3
Thread: WATER LEAK - please help...
    Mar 2013
    1
    Hello,
    I've read a number of post regarding water leaks in the front passenger. My leak seems to be focused on the rear passenger, where the harness is . Coincidently, the windows and other mechanisms stopped working - and its getting hotter out there, cannot go through the summer with this issue
    I'm wondering if anyone else has gone through this issue.
    Thanks in advance,
    Max
    CadillacAsAlways's Avatar
    CadillacAsAlways is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS 3.2L, Luxury Sport, Diamond White
    Aug 2012
    Pittsburgh, PA
    659
    Quote Originally Posted by lazzz
    Hello,
    Thanks in advance,
    Max
    Pull out the carpet from your front passenger side area. See if there is water that runs down along a little trough near the door and into the rear area. If it does, I know what your issue is.
    Jul 2012
    23
    Its probably part of your AC system not draining correctly. I got the same issue i'm trying to fix
  • You may not post replies
