2003 cts oil blew out everywhere and car smoked up
Results 1 to 5 of 5
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 2003 cts oil blew out everywhere and car smoked up in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I bought this 2003 cts without warranty just under 2 months ago. I seen the car fax and it was ...
    senicova is offline Cadillac Owners Member
    Automobile(s): 2003 cadillac cts 3.2L
    Mar 2013
    32
    5
    I bought this 2003 cts without warranty just under 2 months ago. I seen the car fax and it was always serviced at cadillac and was very well taken care of, its just about mint with 150k miles.
    Anyway today.. I noticed i was trailing white smoke, i stopped right away and shut off the engine. The white smoke came from under the hood. What i guess is oil is all over the very bottom part of the front of the engine. The oil just poured out like blood from a head wound with the car off. It seemed like it sprayed everywhere at the bottom with force.
    I tried to look to see where this came from and looking at the front of the engine, its like i see nothing on the engine.. Like the oil sprayed out from under and went forward.
    I had to move the car a little forward which is probably dumb.. But the engine started and sounded fine.. As i moved the car several feet i lacked power.. The engine rpms went up without the car speeding up like it should. I did pull over right away, and theengine sounded good.. Just the oil fell out.
    Seemed mainly on the driverside.. My tire driver side tire had oil on it.. Under the car is where oil was all over the bottom. Looking at the engine from underside seemed clean.. Like it leaked from something under the car next to the engine and sprayed forward.
    Im afaid tomorrow when i have it told they will say my engine is finished. Any idea what happened.. Maybe a seal.. Can it be fixed..
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,110
    Re: 2003 cts oil blew out everywhere and car smoked up
    From the sounds of it. Your problem is not the engine, but the radiator and the piss poor connection for the transmission cooler. For the most part installing an aftermarket cooler will fix this. But hopefully you didn't cause any harm by trying to move it.
    KOT
    Mar 2013
    32
    5
    Quote Originally Posted by Kingoftypos View Post
    KOT
    I really dont think i caused any harm during the move. I dipped my finger in the fluid and it looked to me like oil... Could that be mistaken for oil.. I smelled it and i thought too it more or less smelled like it was oil. But smelling oil isnt a hobby of mine.
    I hope it was what you think it might be.. Any idea on taking it to a garage for how much it might set me back.. I hope under 1000. Thank
    you so much for the quick reply.
  5. #4
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,147
    Transmission fluid is just another grade of oil, so it would be hard to distinguish from the engine oil unless it was brand new. (Tranny fluid is typically red, but once it's run for a while it gets dirty just like engine oil, so it turns brown/black).
    As KOT said, the trans cooler lines and their connections to the radiator are pretty common weak points. Plenty of threads about it. Here's one with some pictures. Some folks have found that it's easier to just plumb an external trans cooler (which you can get at any auto parts store - something like this) rather than mess with the cooler built into the radiator. Again, there have been a number of threads about it, so search around and you should be able to find some "How To"s.
    Also, fill out your profile with your location. You might find that there are CTS enthusiasts near you that can help you install the cooler and save you a bunch of money.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  6. #5
    odthetruth's Avatar
    odthetruth is offline Moderator
    Automobile(s): 2006 CTS-V
    Feb 2010
    NYC
    4,969
    ^ This.
    I would bet it to be the trans cooler lines as well. I've seen these fail. In my opinion, depending on your location, your best bet is an external trans cooler. Would be the cheapest and simplest option to do yourself as well.
    [2006 CTS-V]
    Bolt ons and Bolt ins, and Bolt underneaths.
  7. Remove Advertisements
