Information needed from people that put CTS-V suspension on a CTS 3.6L
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
Like Tree1Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Information needed from people that put CTS-V suspension on a CTS 3.6L in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; ...
    dboydr's Avatar
    dboydr is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac CTS 3.6L
    Oct 2012
    Washington State
    38
    44
    So I ended up buying the complete suspension for a CTS-V (FE4 shocks, Struts, V-spring, front/Rear Sway Bars with only 22K on them!!!) and waiting to get them installed…
    My questions to the people that have done this modification is;
    Did you have to modify anything to the nivomat shocks for ride height? Since I am using the V-Springs I would think that I just install as normal…? But if I lowered it I would do the WW or Mighty Mouse mod to lower in the rear, right?
    After the install I need to do an alignment… did you need the camber kit for alignment or not?
    Is there any other unforeseen items that I might run into or cost to perform the installation of the complete kit???
    Thanks
    ghettomike's Avatar
    ghettomike is offline Cadillac Owners Master
    Automobile(s): 03 CTS 3.2L (Sold) / 09 CBR 600rr /2014 GMC Sierra
    Apr 2008
    off the grid.
    33
    7,872
    Re: Information needed from people that put CTS-V suspension on a CTS 3.6L
    using all the cts-v components you will be fine.
    buy new sway links and you may want a alignment.
    cmjohnson is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS luxury package
    Nov 2003
    300
    I've only put sway bars in. I like the increase in apparent stiffness in cornering.
    I have the soft ride suspension option. Just how much harder will the ride be if I go whole hog and put in all V suspension parts?
    dboydr's Avatar
    Oct 2012
    Washington State
    38
    44
    I am soon going to find out how stiff it will be by going "whole Hog" out. I am excited to find out, i heard it is a bit more harsh. But the handling is a good trade off.
    wait to see
    ghettomike's Avatar
    Apr 2008
    off the grid.
    33
    7,872
    ya... its stiffer. maybe im a oddball but i dont think its that stiff.
    i test drove a fe1 or fe2 cts before i found mine, and honestly i hated the suspension, i almost stopped looking at the cts..glad i discovered fe3 then the V shocks FE4 with eibachs.
    im also one of the rare people who hate the feel of stock rims and love how 20s ride.... i would rather be on a dirt road on 20s than smooth pavement on stockers...
    weird..
    Blayne's Avatar
    Blayne is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS sport model/package
    Sep 2012
    Sudbury, Ontario Canada
    1,058
    If you ever need an alignment, you do not need a camber kit. The camber adjustment is done on the lower control arms. The bolt that holds the control arm to the frame is slotted so the arm can move in and out a bit.
    I just started my coilovers today with plans on a suspension how to. I will also be showing the alignment slots in the frame because I have to make them a bit longer because I will probably be a bit lower than the factory will adjust to. Stay tuned for the write up.
    dboydr's Avatar
    Oct 2012
    Washington State
    38
    44
    That is good to hear that I don’t need that camber kit... I was curious cause I seen the "Eibach Camber & Alignment Kit 2-corner" for use on the pro and street kits. Am I wrong for thinking that you are required or needing this for lowering the car? Or is this just another thing to spend more money on?
    Eventually I will lower the CTS, and did not know if I need these bolts for the +- 1.75 degrees of play over the stock ones?
    http://www.ebay.com/itm/370743681784...84.m1423.l2649
    Quote Originally Posted by Blayne View Post
    coolcat is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2007
    47
    I just finished installing FE4 shocks, a mighty mouse kit, V sway bars, Hotchkis lowering springs and a shock tower brace. The car originally had Fe-1 suspension, the ride is some what firmer but nothing bad unless your on uneven pavement, then your feel some harshness. The car now sits about 1 1/4" lower all around and the guy that did my alignment took the camber settings to the max and the car is still out by about 1 to 1 1/2 degree on every corner. Has anyone out there had any luck with Camber kits? I read somewhere on the forum that someone purchased the Eibach kit and that it didn't work out for them.
    Iceman_jd's Avatar
    Iceman_jd is offline Cadillac Owners Fanatic
    Automobile(s): 2007 3.6 CTS
    Oct 2012
    Arizona
    112
    Can you post what your alignment numbers are now? Also can you measure the distance from the center of the wheel to the bottom edge of the the fender for all wheels. It'll give us a reference on how low is your ride. And like Blayne said the control arms bearing ends go into slotted holes in the frame where the adjustments are made. It could be made at least a 1/4" longer to give you your numbers (if you ride isn't slammed to the ground)
    -1.2 to -1.3 camber up front is good and -1.5 to -1.8 camber for the rear. Go with zero toe up front and 1/8" to 3/32" toe in on each rear wheel.
    Blayne's Avatar
    Sep 2012
    1,058
    Those bolts on ebay may work to give you that little bit more. When I did coilovers, the best I could get was -1 degree all around. That was ok with me cause that's where I wanted it for better corner handling. If you do some aggressive cornering I would try to stay at -1 degree. Your tires won't wear much at that setting. Try the bolt. I will be trying it too cause my stock ones are all seized up
    J W
    J W is offline Cadillac Owners Enthusiast
    Automobile(s): CTS /CTS-V / Escalade EXT / Coupe
    Jun 2009
    583
    If I did D2 coilovers with v front & rear sway bars. Would I have a noticeable harsher ride than I have now. Im currently on FE1s
    Blayne's Avatar
    Sep 2012
    1,058
    Quote Originally Posted by J W
    The sway bars don't give you the harsh ride per say. They just stiffen the car up on side to side movement ie. cornering. I did the D2 coilovers and they have a great ride. And I say this living in an area with horrible roads. Nobody can tell I have coils on by the ride. The performance side of them is great. Awesome ride!!!
    The D2's with the v sways would be awesome. I am currently looking for v sways!
    J W
    Jun 2009
    583
    Thank, I think ill give it a try.
  16. #14
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,224
    Quote Originally Posted by coolcat View Post
    As Iceman asked, what are the actual alignment numbers now, and what are your actual ride heights?
    I'm running about -2.2 up front and a little more in the rear with no adverse tire wear issues. -1 is about the minimum I would want if I had any intention of driving a car aggressively. Improper toe settings are much more likely to cause uneven tire wear.
    Iceman_jd and Iceman_jd like this.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  17. #15
    DavidBoren's Avatar
    DavidBoren is offline Cadillac Owners Enthusiast
    Automobile(s): Volant, VMAX, RX catch can, tranny cooler... RIP
    Jul 2012
    Portland, OR
    31
    518
    Has anyone on here swapped in the A-arms and brakes (and thusly rims, etc) from the CTS-V into the V6 CTS? The CTS-Jr is lighter so the Vee-car parts would be bigger and stronger direct-fit upgrades. Would you have to swap differentials to use the CTS-V rear hubs/brakes? Do those hubs only mate to the Vee axles? And those, in turn, only mate to a Vee-car pumpkin? I guess replacing the CTS-Jr diff with the Vee 3.73 G80 would be nice because you get the lower gears. The only other way to get lower gears is to go to the euro spec differential. And it doesnt matter if you are going for a V6 euro spec (3.93, I believe) diff or a Vee pumpkin, its a $1000 either way. I do not have money to do it all at once, but since I am upgrading to Vee-car sways/springs/FE4's, I might as well keep it going and replace the hubs/control-arms/brakes with the beefier CTS-V equipment. Can anyone tell me exactly what would be needed? Sorry, I dont mean to hijack this thread.
  18. Remove Advertisements
